tv coax routing
dwramler
I have visited both Monaco assembly lines and talked to the wire loom person.  Each coach has a wire loom constructed for that coach.  The loom includes All options that coach can have even though the coach might not include all of the options.  The loom is installed in the coach on the drivers side where the wall and ceiling come together.  Pig tails are then routed to the various areas where the option equipment are located.
The Aladdin system usually connects together with the system behind the rear TV in the cabinet the TV occupies.  Because of the size of the wire loom, it is hard to use a signal tone tracer/probe if that wire happens to be in the middle of the bundle of wires.  Good luck, Chuck B
