Gary Cole Posted November 24, 2021 Share Posted November 24, 2021 (edited) I'm in the process of replacing my Beede gauges with individual gauges. Never liked the combined gauges and poor accuracy. I also wanted to make room for a 10" 1080p quad camera system and a 10" double din stereo system which gives me a 5th 1080p camera. Freed up a lot of instrument panel space with lots of holes left to fill with cool stuff.😀 Still a work in progress. Using the original speedometer and rpm gauge for now until I make a decision. I bottom hinged the fabricated aluminum panels so that they can be opened to provide easy access. Took a lot of cleanup and rerouting of the rats nest to accomplish that. Anyone that has ever looked under a Monaco dash knows what I'm talking about. Might go with GPS speedometer. Hopefully It's far enough along so that I can finish it when I go south with the help of a friendly UPS driver. Does anyone know where the coolant temp sensor is located and if the ECM and gauge shares the same output or the gauge uses a separate sensor. No luck on the Cummins site. Might not know where to look. The Beede gauge naturally uses a sensor with a non standard Ohm range. The photo is of a sensor located on top of the engine which I'm guessing is a high temp sensor as it is powered and seems to be NO at 45 F. The temp sensor to the gauge reads 90 ohms at 45 F and is not affected when I unplug the wires going to the mentioned sensor. Edited November 24, 2021 by Gary Cole 1 Link to comment Share on other sites More sharing options...
johncvandoren@gmail.com Posted November 25, 2021 Share Posted November 25, 2021 Great-looking dash. What did you finish them with? What are your 4th & 5th cameras? I use a remote GPS module from Garmin (no longer made) as camera 1, then Rear, Left, & Right. I also use a separate rear camera always on the radio screen. Please also advise make & model of your 10” quad-view monitor. Link to comment Share on other sites More sharing options...
cpat_39 Posted November 25, 2021 Share Posted November 25, 2021 John, Instead of chasing all the sensor, etc. You might consider BlueFire Adapter and software. https://bluefire-llc.com/store No I am not an agent or rep for this product that I have used for last 3 years in our 2000 Diplomat. BlueFire works through the ECM and gives you more accurate information than the many sensors Monaco installed on the engine. Be happy to communicate with you or anyone else about my experience. Having an older engine I do not get the data available to you with your 2005 engine. Your Fellow Romer Pat C Link to comment Share on other sites More sharing options...
Gary Cole Posted November 26, 2021 Author Share Posted November 26, 2021 (edited) John I purchased the unit from Amazon. Fursam or something like that was the seller. I would make sure the unit is actually full 1080p and supports the AHD camera standard. The first one I purchased was neither. Have to read the fine print on a lot of amazon products these days. Got a brick if anyone needs one. The panels are .125 " aluminum and black walnut veneer. Next time I would use something like tung oil rather than urethane on the veneer. I'm using the 4th and 5th cameras in a high low configuration at the right rear such that I can accurately judge right lane merging distance with the lower camera and see a long view of a street I might have to back into with the high camera. That can be a dangerous procedure at times. Edited November 26, 2021 by Gary Cole Link to comment Share on other sites More sharing options...
Connie B Posted January 23, 2022 Share Posted January 23, 2022 On 11/25/2021 at 12:29 PM, cpat_39 said: John, Instead of chasing all the sensor, etc. You might consider BlueFire Adapter and software. https://bluefire-llc.com/store No I am not an agent or rep for this product that I have used for last 3 years in our 2000 Diplomat. BlueFire works through the ECM and gives you more accurate information than the many sensors Monaco installed on the engine. Be happy to communicate with you or anyone else about my experience. Having an older engine I do not get the data available to you with your 2005 engine. Your Fellow Romer Pat C Pat we are very interested. Was wondering when would be convenient to get more info from you. We are not electronic savvy. lol. Thanks the burnettes Link to comment Share on other sites More sharing options...
cpat_39 Posted January 23, 2022 Share Posted January 23, 2022 I am available all day. Private email me your phone # and I'll give you a call. patcoleman@astound.net. Pat Link to comment Share on other sites More sharing options...
hex_nut Posted October 13, 2022 Share Posted October 13, 2022 Gary Did you ever determine where the Beede temp sensor was installed? My temp gauge has failed and I have determined that the dash gauge does NOT use the same sending unit as the engine ECM. I am not sure how to troubleshoot the dash gauge to determine if my gauge has failed, or if the sending unit has failed. What did you do with the original temp gauge that you removed? Did it still work? Any idea where I can look to find a replacement if I determine that it is my gauge that has failed? Any assistance you can provide in pointing me in the right direction is greatly appreciated. Richard Link to comment Share on other sites More sharing options...
Gary Cole Posted October 13, 2022 Author Share Posted October 13, 2022 (edited) Richard I installed a water temp sender at #6 cylinder for my new gauge. There is a plug on top of the engine at that location. That seemed to be the quickest solution. I determined that my engine has a high temp alarm sender at #1 cylinder and another sender which is buried at the front of the engine. Hope I never have to replace that sender. I was thinking that the original gauge might share the output of that sender with the ECM. The wiring diagram I have does not show how Monaco derived the signal for the original gauge. I did verify that the ohm range is not standard and could not find a new gauge to match it. Edited October 13, 2022 by Gary Cole Link to comment Share on other sites More sharing options...
