LakeBob Posted February 2, 2022 Share Posted February 2, 2022 2009 Dybasty with the TV in the center above the cockpit. Anyone Know how this is mounted? Can’t see any obvious trim or other means to take this out. Thanks! Link to comment Share on other sites More sharing options...
Oregon04Windsor Posted February 2, 2022 Share Posted February 2, 2022 Picture would help, but if it's like mine there was a face frame, then a couple screws up from the bottom of the cabinet and a restraining strap at the back of the TV. You'll have to contort yourself between the dash and windshield to get to it. Have someone to help because they are extremely heavy. Link to comment Share on other sites More sharing options...
Fasthobie16 Posted February 2, 2022 Share Posted February 2, 2022 I had a TV that was mounted I a cabinet on the drivers side. You have to take off the trim wood. The bottom of the cabinet was level. Well,......there’s a tilled shelf inside the TV sits on. So when I took the trim off all of a sudden the heavy analog TV started to come out on me. I had no help so I had to reach in and unplug it while holding the thing. So like the previous poster says. Get help. I put a 40” flat screen there mounted on a articulating mount. Located a block of 2x6” wood and secured in the box to mount the stand. Took lots of measurements to locate it so I could close the TV up tight against the cabinet and swing it out a little towards the center of coach. Still have access in cabinet. Left the old trim off. TV covers the hole. Just strap it up against the cabinet when traveling. Jim 2000 Dynasty 40’ Link to comment Share on other sites More sharing options...
Ivylog Posted February 3, 2022 Share Posted February 3, 2022 Take the black louvers off the back side to access the mounting. I mounted a larger smart TV on the face of the cabinet…not inside as they are very thin around the edges. Link to comment Share on other sites More sharing options...
Old Dog Posted February 3, 2022 Share Posted February 3, 2022 On my 2007 Exe there is a long narrow removable panel on the front side of the cabinet. Once that is popped off, there were two metal brackets at the bottom and a 6"-10" piece of angle iron at the very top that had 3 screws. It was a pain in the ass to remove the TV. Takes 2 people to make sure the TV doesn't fall out. The screws at the top were 3/8" hex and had to use like 20" of extensions and a lot of self control to remove them. Hope yours is different. Link to comment Share on other sites More sharing options...
LakeBob Posted February 3, 2022 Author Share Posted February 3, 2022 Thanks for the feedback. I wont have access to the coach until Saturday, I'll go over the cabinet and send pictures if necessary. Link to comment Share on other sites More sharing options...
LakeBob Posted February 13, 2022 Author Share Posted February 13, 2022 Here's some pics of the TV and the only back panel I can locate. The panel is partially open towards the top and I'm seeing small finish nails holding it in. It's removable, may have to figure out a new method if I remove. Anyone work with anything similar? Thanks! H Link to comment Share on other sites More sharing options...
Ivylog Posted February 14, 2022 Share Posted February 14, 2022 Panel snaps on…just pull it off. Link to comment Share on other sites More sharing options...
RustyH Posted March 9, 2022 Share Posted March 9, 2022 I completely removed the Sony TV from the center overhead and reconfigured the center overhead. The TV is heavy and requires 2 people to remove it, so just be aware of that. There was an angle iron frame on the inside of mine that the TV was resting on and it was easily removed. The center TV cabinet can be removed as an assembly from the roof of the coach and disassembled (quality cabinetry), I used the complete back panel for the new front panel, remove the snap clips from the sides, put some hinges on the bottom of the panel and used 1 of the snap clips on the top to hold it shut. I cut the sides of the cabinet down to look proportional and then reassemble it. Went to Lowe's, got a piece oak, made a back panel, stained it to match, looks like it was made at the factory and the head bonging cabinet is no more! Link to comment Share on other sites More sharing options...
Chargerman Posted March 9, 2022 Share Posted March 9, 2022 When I removed my TV I shortened the center cabinet to match the adjacent ones. After cutting off the bottom I took a section out of it and reattached it. I was fortunate to have two cabinet doors from the desk I removed that luckily were the perfect height to put where the TV was Link to comment Share on other sites More sharing options...
