Flooring Questions For Ernie Ekberg.. or anyone!
2004 Monaco Monarch SE - 37'
Our new, to us, RV has some significant flooring issues from a leaky ice maker and I'm pretty sure I'm going to need new subflooring all the way down to the beams when I pull up the linoleum.  So I have few questions.
1.       What would you recommend for a replacement subflooring material?  And how to protect the bottom?
2.       What are the advantages of “engineered flooring”?
3.       Have you every put in electric floor heat under the engineered flooring?  Is that doable?
4.       I think we are going to put new carpeting on the slide out rather than hard floor so we don’t have to deal with the slide out edge rise and fall when it’s in and out.  Any thoughts on that?
Hope you are doing well.
Thanks for your time and recommendations.
Here's a post that I had done starting last Dec.   Others did comment throughout the project.  Ernie will be the best to comment on types of flooring etc.
I did have to replace a ~4X6' piece of subfloor down to the metal subframe.  I did the best I could to salvage the original vapor barrier, and when laying the new subfloor down I spread liquid nail and then used a roller to press it back up against the wood.  Long term won't know if it worked for a while.
Othe
Edited by jacwjames
