gimesun Posted July 4, 2022 Share Posted July 4, 2022 First let me think all of those that responded to my recent request for information on engine coolant loss. I am working through the thoughts provided and I am currently on a trip to determine if I have a solution or not. This is the first day on my trip and first thing in the morning I checked the windshield wipers and they just froze. I found that you can drive without wipers through mild rain and good roads. I thought perhaps it was a fuse but I have checked both in the front main compartment and the rear and I can’t find a fuse anywhere for the windshield wipers. This is on a 2004 Windsor. Any thoughts or experiences would be appreciated. Thank you. Link to comment Share on other sites More sharing options...
nvrtoofast Posted July 4, 2022 Share Posted July 4, 2022 Double check that the wiper motor is moving. My wipers stripped out the arms and wouldn't move. Had to pull them and use a metal sleeve to tighten up the tolerance to get them working again. Link to comment Share on other sites More sharing options...
BradHend Posted July 4, 2022 Share Posted July 4, 2022 Agree. Check up front for anything obvious, then check power. Should be able to narrow down a possible fuse or where the issue is. Lots of messy wiring under there, but it isn’t so bad once you sort of “isolate it”. As to where the fuse is - not sure - but I would think its in the front driver side electrical bay. According to your manual, its a 10 amp circuit breaker in your front electrical bay labeled MONACO1, circuit is WIPER. Link to comment Share on other sites More sharing options...
Brian J Posted July 4, 2022 Share Posted July 4, 2022 (edited) If you have a smart wheel module check connections in front electrical bay, after tearing everything apart on steering column it turned out to be corroded connector on Smart wheel module. Edited July 4, 2022 by Brian J Link to comment Share on other sites More sharing options...
Tom Wallis Posted July 4, 2022 Share Posted July 4, 2022 If you are not able to get the wipers fixed right away, a good coat of RainX will allow for some driving in even more than a light rain. Link to comment Share on other sites More sharing options...
Georgia Mike Posted July 4, 2022 Share Posted July 4, 2022 I second the RainX. It will at least get you through your trip till you can get home to troubleshoot better. Link to comment Share on other sites More sharing options...
Garry Donohue Posted July 4, 2022 Share Posted July 4, 2022 I drove from New Jersey to Florida in pouring rain with no wipers, RainX was a miracle. It ended up being corrosion under the smart wheel. Just lightly sanded the contacts and has been fine since then. Link to comment Share on other sites More sharing options...
