Hypoxia Posted November 1, 2022 Share Posted November 1, 2022 Has anyone found a source other than Valid for the KIP Manufacturing valve 6X1053 (Y001916) or the rebuild kit for the valve. These are in the 6 Pack and 4 Pack valves. KIP makes some rebuild kits but I haven't had success finding these. Link to comment Share on other sites More sharing options...
vito.a Posted November 1, 2022 Share Posted November 1, 2022 Wow! You're getting in deep already. Our Executive had the Power Gear/Valid leveling system but it worked well so I didn't have to worry. Are they available from Power Gear but just expensive, or has Lippert dropped these parts? What does Newell say or are they the last resort? Link to comment Share on other sites More sharing options...
Hypoxia Posted November 2, 2022 Author Share Posted November 2, 2022 Vito, We are all using the same parts with the Valid system. The basic problems you run into once you enter the manifold are dirt on the valve, that rubbery sealing surface leaking, contamination hindering valve movement or bad electrical coils. Coils are easily available and dirt can be cleaned but the rubbery surface that contacts the seat eventually leaks, KIP makes these parts for Valid and possibly makes rebuild kits. It would be nice if we could find that part number. A typical rebuild kit is $10-$20 vs a lot. Everyone who has that system would benefit by replacing all of those valve seats that are seeping just a little. I have 12 valves, not a big deal, but if we can find a repair kit it would help many. Newell has the best phone customer service I have seen, very similar to the original Monaco support, but I already know what they will say about this. Link to comment Share on other sites More sharing options...
Happycarz Posted November 2, 2022 Share Posted November 2, 2022 When I went to posts this morning, the first time I tried adding picture, it kept saying “Downloading,” then I tried again and picture was “Queued.” So I texted Jim to let him know these are available and should be the correct ones. When Jim returns to town we will verify these are correct. These come from my car wash equipment supplier. Link to comment Share on other sites More sharing options...
96 EVO Posted November 2, 2022 Share Posted November 2, 2022 (edited) Valid only manufactures the electronic's side. Powergear makes (sources), the mechanical parts. Edited November 2, 2022 by 96 EVO Link to comment Share on other sites More sharing options...
Solution Hypoxia Posted November 23, 2022 Author Solution Share Posted November 23, 2022 (edited) Harry was invaluable, once again! The part number he suggested has the proper nipple, I ordered a bunch of KIP SKPA38 from Kleen-Rite. I removed the nipple with my fingernails and used a punch to drive out the old brittle nipples. I replaced all 12 in a couple of hours. The "O" ring is size 019 and the solenoid coil is HydraForce 4301512. Edited November 23, 2022 by Hypoxia Link to comment Share on other sites More sharing options...
Happycarz Posted November 23, 2022 Share Posted November 23, 2022 Thank you for the kind words. Glad the seals worked. $9.00 vs $80.00 per seal is a huge savings, especially when you have 14 air valves in the system. Link to comment Share on other sites More sharing options...
birdshill123 Posted November 24, 2022 Share Posted November 24, 2022 (edited) I would like to have those parts on hand. How many SKPa38 should I buy? What about the solenoid coils? I can source O rings easily, I noticed the solenoids in the list are 24 volt?? What material is preferred for the orings? Edited November 24, 2022 by birdshill123 Link to comment Share on other sites More sharing options...
Hypoxia Posted November 24, 2022 Author Share Posted November 24, 2022 Your Dynasty should have two 6-packs and one 4 pack with a tag axle. That's 16 total. The solenoid coil is 12 VDC and I used Buna 019 "O" rings. Link to comment Share on other sites More sharing options...
MC Newell Posted August 1 Share Posted August 1 Hi everyone, my name is Marcel. I am new to this channel, upon searching on Internet about these particular issues that you guys had in the past with those valves and valve repair kit, I am looking to do the same to my coach, but now I got to the problem where I cannot remove those stem valves off the manifold because of that special tool is needed, does anyone has an idea where I can find that tool ? Link to comment Share on other sites More sharing options...
Dr4Film Posted August 2 Share Posted August 2 It is called a "spanner wrench". Just make sure you get the correct size. They come in hundreds of different sizes. https://www.summitracing.com/parts/nxo-00-56012?seid=srese1&ppckw=pmax-tools&gclid=Cj0KCQiAjMKqBhCgARIsAPDgWly6URa0NlNdYSvCOA_XV3bdE4aeh9BpVQiDuDX25QuVAL3m8PNqhzwaAmsJEALw_wcB Link to comment Share on other sites More sharing options...
MC Newell Posted August 2 Share Posted August 2 2 hours ago, Dr4Film said: It is called a "spanner wrench". Just make sure you get the correct size. They come in hundreds of different sizes. https://www.summitracing.com/parts/nxo-00-56012?seid=srese1&ppckw=pmax-tools&gclid=Cj0KCQiAjMKqBhCgARIsAPDgWly6URa0NlNdYSvCOA_XV3bdE4aeh9BpVQiDuDX25QuVAL3m8PNqhzwaAmsJEALw_wcB Thank you sir, hopefully they will have the right size, The position to where the manifold is located, it’s extremely hard to get to take the measurements for the wrench size, but I’ll try, hopefully I can get to it Thank you sir, hopefully they will have the right size, The position to where the manifold is located, it’sextremely hard to get to take the measurements for the wrench size, but I’ll try, hopefully I can get to it Link to comment Share on other sites More sharing options...
MC Newell Posted August 3 Share Posted August 3 Thank you Dr4 Film Link to comment Share on other sites More sharing options...
