tmw188 Posted December 31, 2022 Share Posted December 31, 2022 Other than JRV Products are there any other suppliers of some new bezels and switches? I like the white. Link to comment Share on other sites More sharing options...
Dr4Film Posted December 31, 2022 Share Posted December 31, 2022 Todd, Northwest RV Supply has some in white but not very many as they are not as common as the black ones. Link to comment Share on other sites More sharing options...
tmw188 Posted December 31, 2022 Author Share Posted December 31, 2022 Ok thanks Richard, black is ok if I can find the labeling ID’s to match? Link to comment Share on other sites More sharing options...
Dr4Film Posted December 31, 2022 Share Posted December 31, 2022 Unfortunately that will be a huge challenge as most surplus stock has disappeared. Your only recourse may be custom made bezels with the specific labels you are searching for. Link to comment Share on other sites More sharing options...
Solution tmw188 Posted December 31, 2022 Author Solution Share Posted December 31, 2022 I found a few on their that will work as long as the footprint is the same which it probably is. Link to comment Share on other sites More sharing options...
Tom Cherry Posted December 31, 2022 Share Posted December 31, 2022 If you have a source of plastic sheet stock, you can make them. Use a Brother or similar label maker and play with the font size. May not be the same, but as long as attractive….it works. I have cut rectangular holes for the snap in switches using a small saw and then files to clean up the edges. I also recently had to replace the actuator on my Exhaust Brake and found a blank Red one and used a white Brother two line label. No one but a purist 2009 Camelot owner would notice. Link to comment Share on other sites More sharing options...
pwhittle Posted January 1, 2023 Share Posted January 1, 2023 These could also be 3D printed. I have done the same type of thing for Aladdin Joysticks. Paul Link to comment Share on other sites More sharing options...
tmw188 Posted January 1, 2023 Author Share Posted January 1, 2023 (edited) Thanks to all I found some NWRV Supply that should work out well and they even came with new switches. Here’s an example for $20 now we can see them. Edited January 1, 2023 by tmw188 Link to comment Share on other sites More sharing options...
Paul J A Posted January 1, 2023 Share Posted January 1, 2023 findmyrvparts.com rvparts.visonerv.com anyrvparts.com finditparts.com Link to comment Share on other sites More sharing options...
tmw188 Posted January 1, 2023 Author Share Posted January 1, 2023 Paul thanks for those additional links I’ll keep them in a file Link to comment Share on other sites More sharing options...
