Daryl Ammons Posted January 2, 2023 Share Posted January 2, 2023 Has anyone had experience working on the power window? Mine goes down fine but when it is coming up the window seems to shift in the frame some which causes it to bind up and stop. I can grab the top of the window and shift it slightly rearward and it will work. It seems like maybe the lower part of the frame may be loose allowing the window to shift some on it's way up. I pulled off the panel below the window and looked but there is a clear plastic barrier preventing me from getting to the lower track so I did not go any further. I have tried track lube and it will help temporarily but then it happens again usually at the most inconvenient time like at a toll booth. Daryl Link to comment Share on other sites More sharing options...
philcarrell Posted January 2, 2023 Share Posted January 2, 2023 The trac the window sits on inside the panel has either gotten loose or it has come out of the trac. have to get inside the panel to fix it. 1 Link to comment Share on other sites More sharing options...
Jdw12345 Posted January 3, 2023 Share Posted January 3, 2023 You might need new window felts! 1 Link to comment Share on other sites More sharing options...
Hypoxia Posted January 3, 2023 Share Posted January 3, 2023 20 hours ago, Daryl Ammons said: Has anyone had experience working on the power window? Mine goes down fine but when it is coming up the window seems to shift in the frame some which causes it to bind up and stop. I can grab the top of the window and shift it slightly rearward and it will work. It seems like maybe the lower part of the frame may be loose allowing the window to shift some on it's way up. I pulled off the panel below the window and looked but there is a clear plastic barrier preventing me from getting to the lower track so I did not go any further. I have tried track lube and it will help temporarily but then it happens again usually at the most inconvenient time like at a toll booth. Daryl Is the Dynasty window the same as the 2007 Signature? Photo attached. If so: Power Window assembly originally manufactured by Atwood, that division was sold to: Challenger Door 1205 E Lincoln St Nappanee, IN 46550 Phone 574-773-0470 challengerdoor.com 3300 Power Window Regulator Assembly Part Number 2-250989 12/2017 Price was $281.00 plus $25 Shipping Total $306.00 Power Window Beltline Weatherstrip.pdf Link to comment Share on other sites More sharing options...
Daryl Ammons Posted January 3, 2023 Author Share Posted January 3, 2023 Jim it does look like my window from the outside view but I haven’t went any further than pulling off the panel and looking in. In next week or so I am going to go ahead and pull the seat out so I can get to it. I wasn’t able to see in there very good but looked like there was a plastic barrier before you get to the window. Is that a moisture Barrier? How does that come out? Is it possible to get it out and be able to replace it. Probably stupid questions but is my first time working on something like that. Thanks for your reply and info Daryl Link to comment Share on other sites More sharing options...
Hypoxia Posted January 3, 2023 Share Posted January 3, 2023 (edited) I'll make a short video of the operation The black plastic tube is what the rod travels in Edited January 3, 2023 by Hypoxia Link to comment Share on other sites More sharing options...
Hypoxia Posted January 4, 2023 Share Posted January 4, 2023 Here's the cable removed from its housing. The window is attached to the bracket at the end. Link to comment Share on other sites More sharing options...
