snoracer Posted March 18, 2023 Share Posted March 18, 2023 Has anyone installed a remote oil filter and /or a bypass oil filter system on a cummins ISL? Sure would be nice to have it in an easier to change location. Link to comment Share on other sites More sharing options...
sg47619 Posted March 18, 2023 Share Posted March 18, 2023 1 hour ago, snoracer said: Has anyone installed a remote oil filter and /or a bypass oil filter system on a cummins ISL? Sure would be nice to have it in an easier to change location. Your so right I’ve thought about it on my 01 Monaco Dynasty 350 Cummins, I get it all over me. 😢 Link to comment Share on other sites More sharing options...
TommyL Posted March 18, 2023 Share Posted March 18, 2023 My arm isn’t long enough to reach it laying down, and not enough room to set up. I do take a hammer and chisel under with me ,punch a hole in the filter an let it drain before removing. 1 Link to comment Share on other sites More sharing options...
sg47619 Posted March 18, 2023 Share Posted March 18, 2023 3 hours ago, TommyL said: My arm isn’t long enough to reach it laying down, and not enough room to set up. I do take a hammer and chisel under with me ,punch a hole in the filter an let it drain before removing. 👍 Link to comment Share on other sites More sharing options...
Paul J A Posted March 19, 2023 Share Posted March 19, 2023 Some one on this site has done that. Recent post. You might visit NAPA for some options. Link to comment Share on other sites More sharing options...
96 EVO Posted March 19, 2023 Share Posted March 19, 2023 (edited) 4 hours ago, TommyL said: My arm isn’t long enough to reach it laying down, and not enough room to set up. I do take a hammer and chisel under with me ,punch a hole in the filter an let it drain before removing. LOL! Yep, that last 1/4 turn is scary! Your not sure if your going to be wearing black engine oil, or not 😂! I try to set the height of the rear of my coach 'just right' so I can reach laying on my back. Edited March 19, 2023 by 96 EVO Link to comment Share on other sites More sharing options...
snoracer Posted March 19, 2023 Author Share Posted March 19, 2023 57 minutes ago, Paul A. said: Some one on this site has done that. Recent post. You might visit NAPA for some options. Thanks Paul A. I tried doing a search for posts about this but had no luck. Do you have a link for that post? Link to comment Share on other sites More sharing options...
Paul J A Posted March 19, 2023 Share Posted March 19, 2023 35 minutes ago, snoracer said: Thanks Paul A. I tried doing a search for posts about this but had no luck. Do you have a link for that post? No i don't. Maybe one of the administrators will chime in. Or email me @ ackermanenter@aol.com Link to comment Share on other sites More sharing options...
Dr4Film Posted March 19, 2023 Share Posted March 19, 2023 11 hours ago, snoracer said: Thanks Paul A. I tried doing a search for posts about this but had no luck. Do you have a link for that post? It took me all of two seconds to find the thread by using the term filter for ISL. Link to comment Share on other sites More sharing options...
snoracer Posted March 19, 2023 Author Share Posted March 19, 2023 Dr4Film - I've seen that post before, but as I originally posted, I'm looking for info on relocating the oil filter. Link to comment Share on other sites More sharing options...
Ivan K Posted March 19, 2023 Share Posted March 19, 2023 (edited) While I don't have an ISL and will not do it to ours, Cummins apparently used to produce the adapter for it. Not a bypass filter. Would make sense for marine applications. I could not find a new part for sale but here is a reference with part numbers for the most important piece, unless you already have one in mind. Piecing the remaining parts should not be that hard. I have a remote setup on an engine that used to see new oil every weekend but for once a year oil change, I will not make much effort and take a chance with additional leak points. Actually, search for 3899624 brings some hits. Edited March 19, 2023 by Ivan K Link to comment Share on other sites More sharing options...
Solution snoracer Posted March 19, 2023 Author Solution Share Posted March 19, 2023 Thanks Ivan, I think that might be just what I'm looking for. 44 minutes ago, Ivan K said: While I don't have an ISL and will not do it to ours, Cummins apparently used to produce the adapter for it. Not a bypass filter. Would make sense for marine applications. I could not find a new part for sale but here is a reference with part numbers for the most important piece, unless you already have one in mind. Piecing the remaining parts should not be that hard. I have a remote setup on an engine that used to see new oil every weekend but for once a year oil change, I will not make much effort and take a chance with additional leak points. Actually, search for 3899624 brings some hits. Link to comment Share on other sites More sharing options...
Dr4Film Posted March 19, 2023 Share Posted March 19, 2023 4 hours ago, snoracer said: Dr4Film - I've seen that post before, but as I originally posted, I'm looking for info on relocating the oil filter. OMG! My mistake! I should get my readers replaced or have my head examined. I totally misread your post. My apologies! 😇 Link to comment Share on other sites More sharing options...
Floyd4949 Posted March 27, 2023 Share Posted March 27, 2023 On 3/18/2023 at 2:19 PM, snoracer said: Has anyone installed a remote oil filter and /or a bypass oil filter system on a cummins ISL? Sure would be nice to have it in an easier to change location. I use this along with a 12" long, 1/2" socket drive extension. It allows me to easily "relocate" my filter to the garage floor😊 https://www.amazon.com/gp/product/B08LT64XB1/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 Link to comment Share on other sites More sharing options...
