rvingstuff Posted May 5, 2023 Share Posted May 5, 2023 I've an '06 Sig and have hooked a hose to the "back flushing input. But when I turn the water on, nothing goes through that connection. How do I get it unstuck/pluged? Thanks. Link to comment Share on other sites More sharing options...
tmw188 Posted May 5, 2023 Share Posted May 5, 2023 Is the rig new to you, has it ever worked? Is it a direct connection or is there a valve before it? Just some questions that needs some answers to. Link to comment Share on other sites More sharing options...
rvingstuff Posted May 5, 2023 Author Share Posted May 5, 2023 Bought 7ish years ago. It's never worked for me. As far as a valve, all I can see is from the outside of the water closet is the hose screw-on to connect the input water to. Link to comment Share on other sites More sharing options...
Guest Ray Davis Posted May 5, 2023 Share Posted May 5, 2023 (edited) The holes where the water sprays are more than likely stopped up with poop & paper. The fix is with an empty tank remove the unit from the tank and drill the water spray holes, usually slightly larger. Reinstall using a little silicone sealer and it should be good. edit--- Mine is on the other side of the coach & water bay, mounted in the end of my black tank. Edited May 5, 2023 by Ray Davis Link to comment Share on other sites More sharing options...
redstickbill Posted May 5, 2023 Share Posted May 5, 2023 Like Ray wrote, the spray holes are likely stopped up. On my Dynasty the spray nozzle is mounted on top of the black tank, on the passenger side, behind the cover for the Aqua-hot, very easy to get to. Bill B 07 Dynasty Link to comment Share on other sites More sharing options...
Dr4Film Posted May 5, 2023 Share Posted May 5, 2023 I am surprised that your 06 Sig has a separate Black Tank back flushing water input for a hose. My 06 Dynasty does not therefore it has a Back Flush valve which needs to be turn ON for the water to flow to the tank. If no valve can be found, like a previous poster stated, you then have to remove the Back Flush valve from the tank and clean the spray ports out until they are open and working correctly. Or you can purchase a new one and install in its place. https://tinyurl.com/454jx2n4 Link to comment Share on other sites More sharing options...
jfbolkovatz Posted May 5, 2023 Share Posted May 5, 2023 The BWT flush line has a back water check valve normally in the bathroom high to the counter top. A previous owner's repair may have been to disconnect and cap the line. Just guesting. Link to comment Share on other sites More sharing options...
Tom Cherry Posted May 5, 2023 Share Posted May 5, 2023 GEE…lucky guys. My backflush fitting is a mount on the set bay panel. On the back is a hard PEX to the back flush fitting or unit on the black tank. That is courtesy of a spy camera on a phone. Major….major job. Totally strip panel. Bend it with the strength of Hercules….or cut into as many have done. Then replace the flush or drill it out. My recommendation for future use…..use it every time you dump. Get a short hose….maybe 3 ft long. Attach that to the BF fitting. Put a full flow 1/4 turn valve on the end. Install a washing machine screen washer there. I can turn ON and OFF my back flush….sometimes a pressure surge helps. The ONLY time I ever had an issue. I hooked up a hose laying around for a while in the yard. SHOULD have pressure flowed or rinsed it out. Bugs and ants had gone after the water and set up a home. That debris shut down the flow. Fortunately, all I had to do was clean the washer screen. It makes it more convenient and I’m get the mixing or pressure surge to stir up bottom…. That’s my take and experience….others have installed the same setup and report better back flushing. NOW…I do have a Sanicon with a clear fitting. But that is a great way to see that all the crap in the bottom (flat bottom tank) does not get dumped on just the first “empty”…. Link to comment Share on other sites More sharing options...
Gweedo Posted May 6, 2023 Share Posted May 6, 2023 When mine wouldn't flush, I used the air fitting I used to use when I winterized, lowered pressure to 30PSI, couple short blasts and it opened right up, two minutes. Put in some Purogene and started using Borax to help keep it clean, been good for two years thus far. Link to comment Share on other sites More sharing options...
Paul J A Posted May 6, 2023 Share Posted May 6, 2023 (edited) On 5/4/2023 at 9:40 PM, rvingstuff said: Bought 7ish years ago. It's never worked for me. As far as a valve, all I can see is from the outside of the water closet is the hose screw-on to connect the input water to. Have you had an opportunity to review your coach manual[s]? Can you post a picture of your water management bay? https://www.monacocoach.com/resources/media/manuals/2006_Signature.pdf is the link for your Coach Manuals. Section 6, page 202 is a description of the procedure you may want to review. You may also try to "shock" the black tank with a 4X recommended chemical, like Happy Camper. Empty the grey and black tanks, just before bedtime. Fill the black tank 3/4 full of water. Add the chemical. In the morning, dump the black tank, and try the back flushing. Just another option. Good Luck Edited May 6, 2023 by Paul A. Link to comment Share on other sites More sharing options...
