4rickyg Posted May 11, 2023 Share Posted May 11, 2023 Need to replace my ball valve seal. 05 Navigator. dometic Model number 3010. Electronic toilet. Does anyone know the model number for the seal and best place to get it?thank you. I've tried cleaning it and plumber's grease,but it doesn't last very long. Link to comment Share on other sites More sharing options...
Tom Cherry Posted May 11, 2023 Share Posted May 11, 2023 20 minutes ago, 4rickyg said: Need to replace my ball valve seal. 05 Navigator. dometic Model number 3010. Electronic toilet. Does anyone know the model number for the seal and best place to get it?thank you. I've tried cleaning it and plumber's grease,but it doesn't last very long. Go to this thread. Your original “file briefcase” which you HOPEFULLY have should have the manual for the toilet. If not, Google one. Read the above post. It has comments….The install manual has a part’s breakdown with a Dometic number. Then Amazon usually has them. There is an O-ring and ball kit. Get the whole assembly with the ball. Typically, the Dometic kits come with the new gas seal that holds it to the floor. Don’t know if you have the wand spray but if you do, get that one. They may have come with or without… that’s it 1 Link to comment Share on other sites More sharing options...
Bandit411 Posted May 12, 2023 Share Posted May 12, 2023 Here is the print with the part number. I got mine from eBay. 1 Link to comment Share on other sites More sharing options...
4rickyg Posted May 12, 2023 Author Share Posted May 12, 2023 Thank you bandit. That's what I was looking for.I ordered one from tweety's r v supply. 1 Link to comment Share on other sites More sharing options...
pwhittle Posted May 12, 2023 Share Posted May 12, 2023 Marinesan.com is another supplier. https://marinesan.com/base-seals-m-o-plug/ Paul Link to comment Share on other sites More sharing options...
Paul J A Posted May 12, 2023 Share Posted May 12, 2023 30 minutes ago, 4rickyg said: Thank you bandit. That's what I was looking for.I ordered one from tweety's r v supply. X2 for Bandit. Link to comment Share on other sites More sharing options...
