Gweedo Posted May 28, 2023 Share Posted May 28, 2023 Good evening all, Just wondering if any of you dealt with this fitting before. My Rad overflow tank is seeping out of the front screw and one of the top fittings. the top fitting has a yellow ring around it, just wondering if this is something special before I rip it off. Already re-sealed the front one. Thanks! And Happy Memorial weekend to you and a special thanks to all of the Veterans!!!!!!!!! Link to comment Share on other sites More sharing options...
DavidL Posted May 28, 2023 Share Posted May 28, 2023 I am assuming the yellow ring is just to protect the end of the hose. Did you already remove a clamp on that hose? or is it a swaged end? Is the fitting leaking where it is screwed in, or is the hose leaking to the fitting? Link to comment Share on other sites More sharing options...
Agpopp Posted May 28, 2023 Share Posted May 28, 2023 Should be a regular parker style barb. The yellow is just a stopper. Cut about 3 inches from the end and reattach with a hose clamp. The factory put clamps on some and not others, and should just be 3/8 heater hose. Link to comment Share on other sites More sharing options...
Gweedo Posted May 28, 2023 Author Share Posted May 28, 2023 Yeah no clamp on it, I'm sure the fitting is leaking because it turns easily. I'll cut it tomorrow and see what's what. The hose doesn't have much play to it. I'll probably get in there and put on a new hose as well. I just wanted make certain I wasn't going to do something to the tank. Thanks, enjoy the weekend.. Link to comment Share on other sites More sharing options...
CLIFF918 Posted May 28, 2023 Share Posted May 28, 2023 Pat, I replaced the tank on my 02 Diplomat Just didn't trust the old plastic. I changed out the small hoses as well they were in bad shape. You can get to them through the hatch in the bedroom closet. The name and phone number for the tank are on the sticker on the tank in the photo Cliff 3 minutes ago, CLIFF918 said: Pat, I replaced the tank on my 02 Diplomat Just didn't trust the old plastic. I changed out the small hoses as well they were in bad shape. You can get to them through the hatch in the bedroom closet. The name and phone number for the tank are on the sticker on the tank in the photo Cliff C Low Fab 541-610-2574 Link to comment Share on other sites More sharing options...
Blacknight Posted May 28, 2023 Share Posted May 28, 2023 I just replaced my overflow tank with a unit from Source Engineering and it fits perfectly. Can anyone tell me where the two hoses on the top of the tank go to? Link to comment Share on other sites More sharing options...
Gweedo Posted May 28, 2023 Author Share Posted May 28, 2023 Thank you for the responses and tank info. Not sure where the hoses go but I will soon. Going to replace them as well since I'm in there. These were supposed to be changed 6-years ago when I asked to have every single water hose replaced. Link to comment Share on other sites More sharing options...
96 EVO Posted May 28, 2023 Share Posted May 28, 2023 I had that fitting weeping a bit, and was lucky enough to have enough excess hose to just turn the fitting another 1/4 turn in the tank. Hasn't leaked since. Link to comment Share on other sites More sharing options...
1nolaguy Posted May 28, 2023 Share Posted May 28, 2023 CLIFF918, I could not enlarge the photo enough to read the sticker. Can you advised the manufacturer/source of the tank? I could not find it via Google. Link to comment Share on other sites More sharing options...
jacwjames Posted May 28, 2023 Share Posted May 28, 2023 FWIW, I replaced my tank back in ~2014. When I first bought my 2002 rig in 2008 I had a couple weeping areas on the tank itself that I repaired using a polyethylene type glue. It held for ~6 years but had a couple other areas start to weep so decided to replace the tank. At that time there were not a lot of options for metal tanks so I bought a similar style but supposidly out of better material. They do not offer the tank anymore so you would have to go with a metal tank https://shop.findmyrvparts.com/monaco-rv-steel-surge-tank-overflow-tank-01806583S-p/190014s.htm I believe the hose that is leaking is the one coming from the top of the engine at the thermostat location. My advice would be to just bite the bullet and replace that hose. On mine that hose was extremely hard and brittle, I didn't even try and use it back, just got the same size at the Autozone near me. That hose actually carries quite a bit of coolant the recirculates in the surge tank and then back to radiator, if it were to fail you would loose a lot of coolant. Link to comment Share on other sites More sharing options...
Bill R Posted May 28, 2023 Share Posted May 28, 2023 @1nolaguy C Low Fab 541-610-2574https://clowfabandperformance.com/products/monaco-surge-tank 1 Link to comment Share on other sites More sharing options...
Agpopp Posted May 28, 2023 Share Posted May 28, 2023 10 hours ago, Blacknight said: I just replaced my overflow tank with a unit from Source Engineering and it fits perfectly. Can anyone tell me where the two hoses on the top of the tank go to? On my 5.9 ISB, one goes to the midpoint of the upper metal coolant pipe and the other goes to the highest point on the engine bypass cooling circuit. Link to comment Share on other sites More sharing options...
CLIFF918 Posted May 28, 2023 Share Posted May 28, 2023 2 hours ago, 1nolaguy said: CLIFF918, I could not enlarge the photo enough to read the sticker. Can you advised the manufacturer/source of the tank? I could not find it via Google. C Low Fab 541-610-2574 Link to comment Share on other sites More sharing options...
Raymond Posted May 29, 2023 Share Posted May 29, 2023 On 5/28/2023 at 7:44 AM, Blacknight said: I just replaced my overflow tank with a unit from Source Engineering and it fits perfectly. Can anyone tell me where the two hoses on the top of the tank go to? The 2 hoses: one has a larger diameter than the other. The larger moves coolant from your turbo and the small diameter is coming from the top of your radiator. 1 Link to comment Share on other sites More sharing options...
Paul J A Posted May 29, 2023 Share Posted May 29, 2023 (edited) On 5/28/2023 at 9:07 AM, Gweedo said: Thank you for the responses and tank info. Not sure where the hoses go but I will soon. Going to replace them as well since I'm in there. These were supposed to be changed 6-years ago when I asked to have every single water hose replaced. https://sourcerv.com/ makes a replacement tanks as well. Look on their home page, lower left hand corner. Edited May 29, 2023 by Paul A. clarify Link to comment Share on other sites More sharing options...
Gweedo Posted May 30, 2023 Author Share Posted May 30, 2023 10 hours ago, Paul A. said: https://sourcerv.com/ makes a replacement tanks as well. Look on their home page, lower left hand corner. I wonder what he charges. I have seen others for $400+ mine looks good but it would be nice to know. Thank you Link to comment Share on other sites More sharing options...
Blacknight Posted May 30, 2023 Share Posted May 30, 2023 Mine was $515.00 shipped to my door. Looks like a quality piece and fit was perfect. Link to comment Share on other sites More sharing options...
Paul J A Posted May 30, 2023 Share Posted May 30, 2023 10 hours ago, Gweedo said: I wonder what he charges. I have seen others for $400+ mine looks good but it would be nice to know. Thank you They would be my choice. Have 1000's in service. It is their engineered product. Link to comment Share on other sites More sharing options...
birdshill123 Posted May 30, 2023 Share Posted May 30, 2023 There is a fellow on IRV that bought a used metal tank from a Peterbilt. Requires a little moding but is large enough and has an external tubular level gauge. That tank is hard to find but if available is a great option Link to comment Share on other sites More sharing options...
Raymond Posted May 30, 2023 Share Posted May 30, 2023 3 hours ago, Paul A. said: They would be my choice. Have 1000's in service. It is their engineered product. In 2018, they were $459.00 for the tank. Link to comment Share on other sites More sharing options...
