gjh2916 Posted July 2 Share Posted July 2 My Aqua hot assembly was not attached to to coach with any fastenerss. Held in place by piping attachments and tight fit in compartment. The tank it self was attached to the pan of the Aqua hot with small pan head bolts Link to comment Share on other sites More sharing options...
Ivan K Posted July 2 Share Posted July 2 I don't remember mounting at the front of our unit, the pump side probably too easy to remember but at the rear I had to get to two L-shape brackets with machine bolts into the floor, a little hard to get to over a cablemaster in my case. Link to comment Share on other sites More sharing options...
Dr4Film Posted July 2 Share Posted July 2 12 hours ago, RobinK said: I know I'm late to the thread - but what is holding the aquahot to the coach? Bolts thru the floor plate, lags into the floor plate. Can you get to them? Obviously you can, but any idea where they are would be helpful. pulling mine out to send in for a replacement unit from John C. Now just to get unit drained, pulled out and everything cleaned up for the new Bosch electric unit while this is all going on. thx With the way Monaco did things so haphazardly you will not know what you are faced with until you put eyes on it directly. The thing is so heavy who knows! Can you explain more about this new Bosch electric unit you posted above? 1 Link to comment Share on other sites More sharing options...
RobinK Posted July 2 Share Posted July 2 gburgman2000 (original poster) mentioned a 4-gal Bosch electric unit as a stopgap while the aquahot was removed. I found a 7 gal unit online - Bosch Electric Mini-Tank Water Heater Tronic 3000 T 7-Gallon (ES8) - that I can hopefully plumb in where the aquahot fresh water was. I'm pulling the cargo tray now and then the aquahot and will hook the new unit up to the same 110v supply the aquahot used, and the cold in, hot out to the same pex lines the aquahot used. That should give me power and hot water to all the locations in the coach - just quite limited supply. It's less than $300. 1 Link to comment Share on other sites More sharing options...
janice Posted July 28 Share Posted July 28 I have a Aqua-hot AHE-100-04s 12VDC/184 Watts --- I m having problems finding parts for this unit -- Does anyone have information were to go-- Thank You John Link to comment Share on other sites More sharing options...
Dr4Film Posted July 28 Share Posted July 28 John Carrillo in Colorado - https://www.heatmyrv.com/ Hydronic Heating Warehouse - https://hydronicheatingwarehouse.com/collections/all-aqua-hot-parts Mister RV Service - https://www.misterrvservice.com/rv-repair/Aqua-Hot-c126277263 eBay Link to comment Share on other sites More sharing options...
RobinK Posted July 28 Share Posted July 28 Update on my AquaHot AHE-100-03S removal and replacement. Have a rebuilt unit from John Carrillo coming on Tuesday. Then the work to get it re-installed. Was a bear to get out. This is a 2004 unit with a couple of thousand hours on the diesel unit. Several Webasto replacements over the years. The exhaust would not budge. I put enough force on the output piece to basically torque the tank inside the unit. Didn't want to break something else, so had to cut it off. Since there is almost zero clearance in the Monaco to get the unit out, had to cut a couple of times to get flush. The Dynasty has a LOT of pipes, wires, etc in that area that needed to be moved around. The gas line to the fridge had to be removed - starting at the fridge side all the way back to the "T" to the stove. Yuck! I put heavy vinyl down in the bay to move the old unit onto. That helped me slide it around and kept any leaking fluid contained. Just slid it out onto a hydraulic shop cart. Pics attached.. Link to comment Share on other sites More sharing options...
Jetjockey Posted July 29 Share Posted July 29 19 hours ago, janice said: I have a Aqua-hot AHE-100-04s 12VDC/184 Watts --- I m having problems finding parts for this unit -- Does anyone have information were to go-- Thank You John Louisville engineering Has lots of parts and lots of knowledge. 1 Link to comment Share on other sites More sharing options...
pcpronze Posted July 29 Share Posted July 29 JetJockey if you will look at previous replies I think you will find your answer. Carrillo is excellent to deal with and there are a lot of parts out there for these units. Link to comment Share on other sites More sharing options...
janice Posted July 29 Share Posted July 29 Thankyou! Link to comment Share on other sites More sharing options...
Paul J A Posted July 29 Share Posted July 29 Another Great Aqua Hot guy , Parts & Service ; Jason Templin 980 253 1721 techntemp@yahoo.com Currently working and residing in Metro Tampa, Fl. area. Link to comment Share on other sites More sharing options...
