bhsl8 Posted July 16, 2023 Share Posted July 16, 2023 Large pine fell on my 2002 Dynasty last night and startled me out of a sound sleep. The front cap has separated on the top and I need a new windshield. Anyone have an idea about how deep I’m in to get damage repaired? There is other damage as well but I think the worst of it’s the cap and glass. 2 Link to comment Share on other sites More sharing options...
Steve P Posted July 16, 2023 Share Posted July 16, 2023 That's rough!!... sorry you are going thru this. Are you traveling, or at home?... Hoping the latter!! Sounds like it might be driveable after the tree is removed. Which will help zero in on the repair costs so you can haggle with your insurance company. Good luck and keep us posted on progress as time permits. If you need a repair facility near wherever you are, someone on Monacoers is sure to know. 1 Link to comment Share on other sites More sharing options...
Martinvz Posted July 16, 2023 Share Posted July 16, 2023 Brouck, That is not good and so sorry to see that happen. You did not share your current location and difficult for us to recommend a local facility. It may take some time before a repair facility could repair it. I would suggest you seal it all with tape, thick plastic and Dicor before and again after driving to your final destination. Link to comment Share on other sites More sharing options...
timaz996 Posted July 16, 2023 Share Posted July 16, 2023 Get some of this to seal your coach. I carry this for just this kind of reason. 1 Link to comment Share on other sites More sharing options...
Reka52 Posted July 16, 2023 Share Posted July 16, 2023 Windshield is an ez fix the cap is fibreglass so it is fixable if that is the only damage you might have got off lucky. Went thru a similar situation a couple years ago and all worked out coach was repaired and not ONE problem since then 1 Link to comment Share on other sites More sharing options...
FLynes Posted July 17, 2023 Share Posted July 17, 2023 Oh that made me sick, when I saw the pics. Good thing no one was hurt. Hopefully you’re fully insured. 1 Link to comment Share on other sites More sharing options...
Dr4Film Posted July 17, 2023 Share Posted July 17, 2023 So sorry that you now have to deal with a problem that the campground owners should have dealt with BEFORE this happened to you by the looks of that DEAD tree. I would seal everything up tight with the water tight Flex Seal Sheets. https://flexsealproducts.com/#1 1 Link to comment Share on other sites More sharing options...
Craggar Posted July 17, 2023 Share Posted July 17, 2023 Hope it all works out for you. I have a tree close enough that could do some damage that needs to come down. Maybe I should get on that pretty soon. Link to comment Share on other sites More sharing options...
