Joel Sheriff Posted March 28 Share Posted March 28 My slide gear is slipping on my front roadside slide 14 ft of my 2007 Monaco diplomat paq. I have had a number of calls into shops and they all don't seem to want to work on it cuz they come up with a reason not to keep the appointment. I had a tech out to my coach and he said it's too big a job to do on the road they need a forklift or other equipment. Any suggestions I'm in Southern California in Acton I'm getting stonewalled by everybody. Please advise Link to comment Share on other sites More sharing options...
Garry Donohue Posted March 28 Share Posted March 28 Is it hydrolic or electric? Link to comment Share on other sites More sharing options...
Joel Sheriff Posted March 28 Author Share Posted March 28 Electric and with some physical labor will come in and go out. Motor sounds OK and bolts not sheared. Link to comment Share on other sites More sharing options...
Garry Donohue Posted March 29 Share Posted March 29 I had the same problem but mine was hydrolic. Link to comment Share on other sites More sharing options...
jacwjames Posted March 29 Share Posted March 29 When was the last time you lubricated the gears/rollers/bearing surfaces. Link to comment Share on other sites More sharing options...
Reka52 Posted March 29 Share Posted March 29 Is it a kitchen slide (cabinets,sink and stove? Link to comment Share on other sites More sharing options...
Joel Sheriff Posted March 29 Author Share Posted March 29 Yes Can't really get to it for lube but pix someone took shows wear on gear teeth Link to comment Share on other sites More sharing options...
Joel Sheriff Posted April 1 Author Share Posted April 1 I have to find out how many teeth are in my gear mechanism for the slide in front roadside onmy Monaco 07 diplomat paq. Link to comment Share on other sites More sharing options...
Joel Sheriff Posted April 2 Author Share Posted April 2 I'm trying to found out for my tech, how many teeth are in the gear for my front roadside slide. I have two, Monaco Diplomat 07, paq. Sorry if a duplicate post but I don't know if anyone followed up on the original post. Moderator Edit. This topic was a duplicate. It has now been edited and combined with the original. Link to comment Share on other sites More sharing options...
Russ R Posted April 2 Share Posted April 2 I am not sure about yours, but some are 21- tooth. https://arcorpidaho.com/product-tag/368967?fbclid=IwAR1Tjg0LDMGSbdyJhucItSKJtNw62RWdWzN9LbAUbyC56mhN_F1OiEddSfw Link to comment Share on other sites More sharing options...
Joel Sheriff Posted April 2 Author Share Posted April 2 I've got to give him correct info anyone know what they put in the 07 Diplomat or could it have been either? Link to comment Share on other sites More sharing options...
Russ R Posted April 3 Share Posted April 3 There are many different ones. You need the model of the slide. If you have a Power Gear slide, attached is a picture of what to look for. So more information is needed to figure out which one you need. Link to comment Share on other sites More sharing options...
Joel Sheriff Posted April 3 Author Share Posted April 3 Russ, where might this info be and should it be accessible. I didn't see any labels near the gear in my original photo. TIA Joel Link to comment Share on other sites More sharing options...
Joel Sheriff Posted April 3 Author Share Posted April 3 (edited) Found on our parts list some slide gear info but still can't find out if 15,18 or 21 teeth after on my coach. Is there a work around to finding the correct gear without getting in there and removing the original gear Edited April 3 by Joel Sheriff Add info Link to comment Share on other sites More sharing options...
Russ R Posted April 3 Share Posted April 3 Are your slides Power Gear or LCI? Link to comment Share on other sites More sharing options...
jacwjames Posted April 3 Share Posted April 3 There should be a sticker on the motor, with that you might be able to figure out the slide system itself. There may also be a controller specific to the system that might help identify. Look at any other parts you can see to try and find a part number. Post any numbers you come up with and I'll try and help source info Most of the info I've accumulated is older for my coach but may be helpful. Attached is a service manual for Power Gear slides. It does have info on how to troubleshoot and service. If you do find a part number on a part do a search in this document to see if you get hits. PowerGearSlides-ServiceManual.pdf Link to comment Share on other sites More sharing options...
Tom Cherry Posted April 3 Share Posted April 3 11 hours ago, Joel Sheriff said: Found on our parts list some slide gear info but still can't find out if 15,18 or 21 teeth after on my coach. Is there a work around to finding the correct gear without getting in there and removing the original gear You need the specifics. Don’t know the “logistics” of where the motor and such are. HOWEVER many of us own and use a “camera”. See the photo. It can be used, wirelessly, with a PC or phone or twblet. I use my iPad for a larger screen and more detail. The camera “box” has a wireless transmitter….and it shows up as a “router” or like a wireless connection you might use at a restaurant or library or such. You “connect” to it. Then the camera’s lens appears on the screen. You watch that and then insert it into a “blind” cavity. Great for looking to see how stuff is attached. If you can snake the camera snd see the motor or drive…..you will get PN and such. Saved many of us a LOT of work . VERY reliable, the black cord is sort of stiff, but flexible….so you can prebend or move or twist around. If you ever need to pull an HDMI cable from a device….and not remove it….you can move the camera behind it and then see your hand snd the HDMI end and the “hole” and it is easy to plug in. Amazon sells them. This is the one I ordered….I think Frank McElroy recommended it….probably others out there. Just look at the ratings. There is an LED light to provide illumination Good Luck 1 Link to comment Share on other sites More sharing options...
Joel Sheriff Posted April 3 Author Share Posted April 3 Thanks gentlemen, the info Tom is great but I need to buy the camera. I'm getting worse in mobility so I'm going to leave that up to my tech. Nice guy let's meet buy parts if I can get cheaper etc. JIM, that's a great manual, it should help alot when I get to the replacement. It may even help the tech. You guys are a big help, thanks very much AGAIN. JOEL Link to comment Share on other sites More sharing options...
Les Hurdle Posted April 3 Share Posted April 3 Hi Joel, I may have someone who can help you Les 661 304 6556 Link to comment Share on other sites More sharing options...
Joel Sheriff Posted April 12 Author Share Posted April 12 I was hoping someone with an 07 Dip had the issue and knew how many teeth were on my gears. I guess it's run it course so I'll inquire elsewhere for hopefully an exact answer. Thanks all e can close out this thread Link to comment Share on other sites More sharing options...
Joel Sheriff Posted July 10 Author Share Posted July 10 As follow up to my previous discussion on my slide gears. I had a technician take out the gear installed by Monaco and it turns out to be a 25 tooth. Lippert is the only one available and they don't have it. Does anyone know where else I can look to replace a 25-tooth slide gear. Or who made the original. There is no previous discussion on who may have made and distributed the 25 tooth gear. How about the salvage Yards, can you tell by sight or measurement if a used gear is worth it. TIA Joel Link to comment Share on other sites More sharing options...
jacwjames Posted July 10 Share Posted July 10 Do you have a part number, can you post pictures? Link to comment Share on other sites More sharing options...
Tom Cherry Posted July 10 Share Posted July 10 NEWS FLASH... Joel, with just sheer DETERMINATION.... is THIS what you need....??? https://www.unitedrv.shop/product/gear-pack-er-w-roll-pins-assembly I wrote the REST and then just decided NOT TO GIVE UP....I found a lot below...but NOBODY had them in stock... The correct PN is, if this is right... 014-140418 IF SO....you had better check it out and order...this, as far as I can TELL is the only thing that seems TO FIT the limited info that you provided......but again...I used 25 Teeth and Lippert and Slide Gear and just kept hammering away and got info off various sites.... Now, I do request that you read the rest. As I searched, I kept adding links....but in the end.. I backed off and tried a NEW search. Let us KNOW... BUT if it works...then please read what I wrote below...as it is what one must do to find things... Joel. NEED PART NUMBER. Pictures with measurements of a TAPE MEASURE along side it. However, I'd get on the PHONE. NWRVSUPPLY has 4 pages of HITS or items if you use SLIDE GEAR. https://www.nwrvsupply.com/?s=slide+gear&post_type=product&type_aws=true NOW, there are many with the number of TEETH. ARE YOU SURE about the TEETH. There are 15 and 24. However, there is a "common one" and all it has is the Part Number. You MUST have the OEM Part Number. SO, if you have that...then start to search...for example... Have you GOOGLED "25 Tooth Lippert Slide Gear" That gets a BUNCH of hits. over 20 or so...and some are the same. BUT...none are 25....Here is ONE.. I counted and it is 26... Does it look the same? NO IDEA? Will it fit" No IDEA. With a GEAR, you need the OEM or you need pictures and dimension of the overall diameter and the shaft size. Does it have Allen Screws or a Keyslot or both. WAY TOO LITTLE info for us to help. https://unitedrvparts.com/products/lippert-crown-gear-slide-out-gear-116658?variant=45365678965039¤cy=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw4ri0BhAvEiwA8oo6FzUaKiCPQJKxrAIlIsV2whUZ_bT3WP9y_Yet6Ymw5pKdUSTNtVXNyxoC76gQAvD_BwE Get MORE specifics than "25 Tooth Lipper Slide Gear".... OK...curiosity... HERE IS A LIPPERT PART NUMBER... 140418 https://store.susqrv.com/index.php?p=detail&item=5520418 NOW....is THIS what you need? https://pdxrvwholesale.com/products/lippert-embedded-rack-gear-pack-assembly-140418 Link to comment Share on other sites More sharing options...
Joel Sheriff Posted July 10 Author Share Posted July 10 I'll call the tech who had the gear and is searching. I'll get the info and pix needed. This one Tom, looks very close but he has the actual gear assembly so I can't match up exactly. I'm going to get shaft measurements, space between holes actual gear count etc I asked him to bring me the part so I can check correctly. Thanks Joel 140418 looks very similar from my recollection when he removed it but that's the issue. Tech said everyone is out of stock on this particular tooth count Link to comment Share on other sites More sharing options...
Tom Cherry Posted July 11 Share Posted July 11 15 hours ago, Joel Sheriff said: I'll call the tech who had the gear and is searching. I'll get the info and pix needed. This one Tom, looks very close but he has the actual gear assembly so I can't match up exactly. I'm going to get shaft measurements, space between holes actual gear count etc I asked him to bring me the part so I can check correctly. Thanks Joel 140418 looks very similar from my recollection when he removed it but that's the issue. Tech said everyone is out of stock on this particular tooth count Good. It appears that Lippert had TWO PN for the same part..or maybe there was one that they sold and one that their distributors sold. The 140418 gets HITS...and there was a CROSS reference that said REAL PN is 014-140418. If that is NOT the one, then you need to get the PN that the Tech said that you need and Lippert doesn't make or doesn't have in stock. THEN SIT DOWN AND SPEND a lot of time googling. Let us know.... Link to comment Share on other sites More sharing options...
