BMulvenna Posted May 15 Share Posted May 15 On our 2004 Dynasty, both of my 22.5 steer aluminum rims are cracked due to extreme over tightening by a tire installer. No they won't stand behind them. Any suggestions on brand are appreciated. Also are they stud piloted or hub piloted? Thanks for any suggestions Link to comment Share on other sites More sharing options...
klcdenver Posted May 15 Share Posted May 15 I am pretty sure you have hub piloted but you can match yours to the attached. Link to comment Share on other sites More sharing options...
DavidL Posted May 15 Share Posted May 15 (edited) Any chance someone swapped from Hub to Stud nuts by mistake? That would not be good for the aluminum rim. I can't imagine how much torque would need to be applied to a Hub nut to crack a rim. Suggesting this to double check what is supposed to be there, not what's on a cracked wheel. A good way to check is if the hub has a very tight fit to the interior hole of the rims to align the two. It's very likely you have Hub nuts. Edited May 15 by DavidL Link to comment Share on other sites More sharing options...
jacwjames Posted May 15 Share Posted May 15 There should be some numbers stamped on the rim itself, do a search using the number and it will get you to the manufacturer. Back in 2009 we were planning on making a trip to AK and I decided I wanted to carry a mounted spare, never needed it but good insurance. I found my rim was made by Accuride so I contacted the company with my part number. Unfortunately the rim was obsolete, the changed the shape of the holes. The rep gave me a substitute number that would work and the name of a vendor they recommended. I ended up buying the rim from Florida Shores Truck Center, cost $264 delivered. My PN was 29644ANP but yours may be different. 1 Link to comment Share on other sites More sharing options...
BMulvenna Posted May 15 Author Share Posted May 15 4 minutes ago, jacwjames said: There should be some numbers stamped on the rim itself, do a search using the number and it will get you to the manufacturer. Back in 2009 we were planning on making a trip to AK and I decided I wanted to carry a mounted spare, never needed it but good insurance. I found my rim was made by Accuride so I contacted the company with my part number. Unfortunately the rim was obsolete, the changed the shape of the holes. The rep gave me a substitute number that would work and the name of a vendor they recommended. I ended up buying the rim from Florida Shores Truck Center, cost $264 delivered. My PN was 29644ANP but yours may be different. Link to comment Share on other sites More sharing options...
Solution vito.a Posted May 15 Solution Share Posted May 15 Monaco used Accuride aluminum wheels. They are 22.5" diameter X 8.25" wide. They are available in XP (high polish) or SP (standard polish). if you place a C after the XP in the part number (example XPC) then they are also coated. Our coach came with coated wheels but I've seen others that are not coated. As Jim stated the unique Monaco hole design died when Monaco closed up. But, there are several others designs available and as long as the front two match it should look fine. https://www.accuridecorp.com/products/aluminum-wheels You could also replace them with Alcoa aluminum wheels as long they are the same specs. Good luck! 1 Link to comment Share on other sites More sharing options...
amphi_sc Posted May 16 Share Posted May 16 Vito gave the Accuride web site. You might want to check the specs on these numbers vs your front axle weights. Holes are round not the Monaco D so won't match your other ones 43644 7400 lbs 40008 8100 lbs Link to comment Share on other sites More sharing options...
