wamcneil Posted May 28 Share Posted May 28 So, it looks like I will need to learn about kwikee steps now… This part apparently lost a couple fasteners and then broke. Are parts available for these steps? The motor and gear seem to be ok. But need to grab the step and help it to full extension Link to comment Share on other sites More sharing options...
Tom Cherry Posted May 28 Share Posted May 28 Did a search…kwikee & parts….try these….otherwise call Lippert. They have, and many here also, the instructions and parts list. https://www.monacoers.org/search/?q=Kwikee parts&quick=1&type=forums_topic Assume you have lubed and done the PM. A word of caution from an Ex Safety Director. If there is hesitation and/or binding, odds are the gear in the motor is worn. That is a dangerous condition, at least on the Coach Step. If the gear is worn and the steps will not “LOCK” in place when extended, then they will “collapse” when weight if put on them as someone exits the MH. My 16 YO GD was able to “catch herself”. My 70 odd wife, with a bad knee (now replaced) might not have been so lucky. I investigated so many simple falls during my career where there was permanent and debilitating injuries that I fixed it immediately with a new motor and solid gears…. 1 Link to comment Share on other sites More sharing options...
wamcneil Posted May 28 Author Share Posted May 28 Well, not finding much useful information. The specific model 903506000 was discontinued and I’m not finding any parts list references to it, except for a rather expensive gearbox and controller upgrade. And found a lippert motor that includes the cast aluminum cover like mine that looks like it might work, but I don’t need a motor at this point. But I found a used gearbox that looks very similar to mine. So I think I’ll go out on a limb and get the used assy and see if it fits. if that doesn’t work I might need to go a more expensive route…. Either way, I might have some more information for the community parts list when I am done. Link to comment Share on other sites More sharing options...
Tom Cherry Posted May 28 Share Posted May 28 6 minutes ago, wamcneil said: Well, not finding much useful information. The specific model 903506000 was discontinued and I’m not finding any parts list references to it, except for a rather expensive gearbox and controller upgrade. And found a lippert motor that includes the cast aluminum cover like mine that looks like it might work, but I don’t need a motor at this point. But I found a used gearbox that looks very similar to mine. So I think I’ll go out on a limb and get the used assy and see if it fits. if that doesn’t work I might need to go a more expensive route…. Either way, I might have some more information for the community parts list when I am done. great. Just be aware that 90 plus percent of the repairs, are a new motor and the older ones, even yours, were tougher. Get it back together and test it...but if it "bobbles" or is ratchety.....then be safety conscious... Keep up posted... Link to comment Share on other sites More sharing options...
jacwjames Posted May 28 Share Posted May 28 From my experience the step isn't very robust. I'd recommend changing the whole mechanism. Pay me now or pay me later. 2 Link to comment Share on other sites More sharing options...
wamcneil Posted May 28 Author Share Posted May 28 2 hours ago, Tom Cherry said: great. Just be aware that 90 plus percent of the repairs, are a new motor and the older ones, even yours, were tougher. Get it back together and test it...but if it "bobbles" or is ratchety.....then be safety conscious... Keep up posted... Ok. I’ll make sure the mechanism is working right! Link to comment Share on other sites More sharing options...
Davidsharp Posted May 29 Share Posted May 29 Etrailer has replacement part acording to them. Worth a try. 1 Link to comment Share on other sites More sharing options...
johncvandoren@gmail.com Posted May 29 Share Posted May 29 There are severaL models that use similar motors and gears, and similar steps that use same motor yet different gear. Make sure you get the exact match. BTW: if you end up replacing the whole assembly, there’s no harm in having spare parts. I carry a spare motor and gear assembly, as they are common failure points. 1 Link to comment Share on other sites More sharing options...
Davidsharp Posted May 30 Share Posted May 30 I have the kwikee 38 series single step, and the armature shaft is one piece with worm gear machined on shaft. Found exact replacement on amazon. Had to order whole gear box as its one piece. Kept old one and new plastic gear just in case this one strips out. But so far so good. 1 Link to comment Share on other sites More sharing options...
Paul J A Posted May 30 Share Posted May 30 (edited) On 5/28/2024 at 4:07 PM, wamcneil said: Ok. I’ll make sure the mechanism is working right! Apply Boeshield T 9 Liberally to the "entire" step assembly . Great product and does not attract/retain dirt, etc like WD 40 does. Exposed linkage loves it!!! Edited May 30 by Paul J A 1 Link to comment Share on other sites More sharing options...
wamcneil Posted May 30 Author Share Posted May 30 (edited) Well, I ordered a used gearbox and motor assy off eBay. Looks very similar. Fingers crossed that it will work as replacement ! Edited May 30 by wamcneil Link to comment Share on other sites More sharing options...
wamcneil Posted June 9 Author Share Posted June 9 Ok, got the new (used…) motor and gearbox installed. Pretty much identical to the original unit. Finding parts for my step specifically was hard because the step was apparently discontinued long ago and it doesn’t appear in any service parts lists that I could find. Maybe they revised the design at some point and removed the external brace on top of the motor. As far as I can tell, the gearboxes are all pretty standard with two types of lever arms. There’s an old style controller (like mine) and a new style controller, but I don’t think the gearbox cares which kind of controller it’s connected to. In my case, I probably could have just replaced the external brace, but as far as I can tell it’s not available separately. I did find a replacement motor with the external brace (lippert/kwikee 379608) but it’s $156. The controller uses a magnetic switch held onto the gearbox by double sided tape. That’s just a sensor for the step light, right? My step light has either been burned out or otherwise nonfunctional since before I got the rig and I haven’t been motivated to fix it. The step is working fine with the switch installed Link to comment Share on other sites More sharing options...
Tom Cherry Posted June 9 Share Posted June 9 2 hours ago, wamcneil said: Ok, got the new (used…) motor and gearbox installed. Pretty much identical to the original unit. Finding parts for my step specifically was hard because the step was apparently discontinued long ago and it doesn’t appear in any service parts lists that I could find. Maybe they revised the design at some point and removed the external brace on top of the motor. As far as I can tell, the gearboxes are all pretty standard with two types of lever arms. There’s an old style controller (like mine) and a new style controller, but I don’t think the gearbox cares which kind of controller it’s connected to. In my case, I probably could have just replaced the external brace, but as far as I can tell it’s not available separately. I did find a replacement motor with the external brace (lippert/kwikee 379608) but it’s $156. The controller uses a magnetic switch held onto the gearbox by double sided tape. That’s just a sensor for the step light, right? My step light has either been burned out or otherwise nonfunctional since before I got the rig and I haven’t been motivated to fix it. The step is working fine with the switch installed Folks spend a LOT of time on step lights. Mine never worked, I think, new. Way low, perhaps never made my “Now, exactly why am I stressing over fixing something that will take an untold amount of labor but will not add any real enjoyment to my RVing Experience?” list….yes….why bother?? 1 Link to comment Share on other sites More sharing options...
wamcneil Posted August 28 Author Share Posted August 28 In case anybody is searching for info on that step switch... I suspect that the magnetic switch does control the courtesy lamp underneath the step. I may never know for sure because I'll probably never get interested in getting mine to work... But more importantly to me... that magnetic switch definitely controls the STEP OUT warning light on the dash. Didn't notice that till the next time I moved the rig. And of course by that time I had thrown away the old gearbox with magnet still attached and had to buy a replacement magnet 😶. Link to comment Share on other sites More sharing options...
Dr4Film Posted August 29 Share Posted August 29 When the rotating arm broke in two on the Windsor single step, there were no parts available so I had to purchased a complete upgraded system which I found on Amazon for $340, part #379145. Good luck with your eBay used part! Link to comment Share on other sites More sharing options...
