waterskier_1 Posted June 1 Share Posted June 1 8 hours ago, jacwjames said: Here's a graphic I found that shows the comparison between a Leece Neville and Delco Remy alternator. Has the same number of wires, different locations. DUVAC system - Leece Neville or Delco Remy.pdf 323.74 kB · 7 downloads Correction, 1. The term "Coach battery" should read "Chassis battery". House ands coach are used interchangeably, but the DUVAC wire connects to the Chassis battery. 2. Don't let the nomenclature "Indicator/Ignition" confuse you. That terminal is for the ignition. Some may reach that as the ALT-FAIL Indicator system, which it is not. 3. The smaller wire Tha connected to one of the three smaller studs on the L/N alternator drawing is the ALT-FAIL and Tach (if not ECU generated). I'm not sure which of the terminals that would connect to on the Delco, maybe the only remaining terminal, labeled "R", or maybe it's not a direct replacement. - Rick N Link to comment Share on other sites More sharing options...
Just Jim Posted June 1 Share Posted June 1 When I replaced my alternator on my old coach the alternator shop could not figure out how to wire it. They said that the "exciter" wire was constantly powered... did not turn off with the ignition....and would drain the battery down. So, my solution was a trickle charger when ever I parked it for any length of time. Having that experience, when I bought my current coach and it was showing signs of failure, I had the existing alternator rebuild. I was fortunate that I was not stuck out of town somewhere. Good luck and keep us posted with your repairs. Link to comment Share on other sites More sharing options...
96 EVO Posted June 1 Share Posted June 1 2 hours ago, malcoll said: I am up in Banner Elk this weekend with a gathering of Porsche 928 owners! Always wanted one of those! Are they flat towable? Link to comment Share on other sites More sharing options...
malcoll Posted June 1 Author Share Posted June 1 23 minutes ago, 96 EVO said: Always wanted one of those! Are they flat towable? No...I trailered it on a u-Haul auto transport. Link to comment Share on other sites More sharing options...
96 EVO Posted June 1 Share Posted June 1 They were a beautiful car in their day, and I think, still are! Link to comment Share on other sites More sharing options...
