Wayne Thomas Posted May 31 Share Posted May 31 (edited) 2002 Monaco Windsor PKD. Would like to change existing 2 bowl kitchen sink to a one bowl without altering countertop. Anyone have any suggestions? Thank you. Edited May 31 by Wayne Thomas Pics Link to comment Share on other sites More sharing options...
JDCrow Posted May 31 Share Posted May 31 Got pics? I would think of 2 possible solutions, both would require a large sink to cover both sink holes since you want to retain the original countertop Link to comment Share on other sites More sharing options...
jacwjames Posted May 31 Share Posted May 31 Here's a site that have some typical sinks. Not sure what size your original sink it. If your lucky enough to find a single bowl the same size it might be possible to do an exchange. Biggest issue may be to the location of the faucet. If you found a slightly larger sink you could use a trim round over bit to enlarge the existing opening. Link to comment Share on other sites More sharing options...
Wayne Thomas Posted May 31 Author Share Posted May 31 What is the site? Link to comment Share on other sites More sharing options...
jacwjames Posted May 31 Share Posted May 31 Here ya go https://www.recpro.com/rv-kitchen-sinks/?mode=4 Link to comment Share on other sites More sharing options...
Dr4Film Posted May 31 Share Posted May 31 The hardest part is finding a single bowl sink with the exact dimensions you have now. Good luck! Link to comment Share on other sites More sharing options...
windsorbill06 Posted May 31 Share Posted May 31 (edited) You have an 'under mount' sink. Little more tricky to install them. And the edge detail of the solid surface (Corian), is nicely finished since it's visible. In a home application, it always costs more to do a under mount installation. You can remove that one and find another that will drop in from the top. Typically called 'drop in' or 'self rimming' sinks. You can cut the corian somewhat to make it fit as the sink will hide the edge of the corian. I think it would be very unlikely you can find an 'undermount' sink that will fit exactly in that opening--but worth looking into. You need your exact sink measurements. here's an example of self rimming sinks https://www.homedepot.com/p/Glacier-Bay-33-in-Drop-In-Single-Bowl-20-Gauge-Stainless-Steel-Kitchen-Sink-VT3322A18/317041458 Edited May 31 by windsorbill06 1 Link to comment Share on other sites More sharing options...
mrbill1951 Posted June 1 Share Posted June 1 Here is ours. I purchased the sink from Lowes. Had do a little modification under the sink cabinet, but didn't touch the counter top. 1 Link to comment Share on other sites More sharing options...
