I installed the Fass fuel pump using the kit from Ultra RV Products. It’s the UP95G - Heavy Duty Lift Pump for Cummins ISB / ISC / ISL CAPS Fuel System. The link to the page is: https://www.ultrarvproducts.com/UP95G-Heavy-Duty-Lift-Pump-for-Cummins-ISC-ISL-CAPS-Fuel-System
The kit comes with the wiring harness and a relay set up to be plugged in to the old lift pump wiring harness (to keep the ECM Happy). I capped the original fuel lines for now and will remove them and cap the inlets at the old lift pump.
This kit uses the original fuel return lines. No need for another dedicated return line. Took about 5 hours (had to run an ignition signal wire, hardest part of job).
Installation photos:
Pump installed:
New fuel line from primary filter to Fass Inlet
Fass pump Mounted at rear of coach with pressure gauge  and new fuel line to secondary filter
Routed new line along same route as original fuel line
New fuel line from Fass (right side of filter) to Secondary fuel filter
  • 1 month later...
I installed the Fass fuel pump using the kit from Ultra RV Products (Posted above) and decided to describe the CAPS lift pump so people can see how to utilize what is there. I had a lift pump that I bought at a flea market. Just never installed it. So here are photos and information. I know that a few people wondered what the CAPS Lift pump looked like
The Banjo ports are NOT connected to the Inlet or Outlet in any way. Currently my inlet and outlet fuel lines are capped where I removed them. The Banjo return fuel line is a 5/8" fuel line to the tank.
image.png.fab3eec915486efa856b60fc683bc82e.png image.png.b45998a90ede8342a21fec28f3eff279.png
