rbowlesusa Posted June 18 Share Posted June 18 I have 2 lights that are out on my 2006 executive denali iiir. One is a fog light and the other one is one of the rear lights. The rear one is glued in. Do the 2 screws on the back release the front cover? I ran out of daylight before I could look at the front light. Any suggestions on replacing it? Thanks in advance! Link to comment Share on other sites More sharing options...
Paul J A Posted June 18 Share Posted June 18 Look up the DOT or SAE# on the lens. Link to comment Share on other sites More sharing options...
Solution rbowlesusa Posted June 21 Author Solution Share Posted June 21 I was able to get the fog light bulb from O'Rilley auto parts. This weekend I will try to fix the rear light. Link to comment Share on other sites More sharing options...
rbowlesusa Posted June 23 Author Share Posted June 23 I'm not sure where to get a replacement reverse light. There are no numbers on the housing. I can not get it apart to replace bulb. Looks like it is around 3.5" round. It was glued in. Link to comment Share on other sites More sharing options...
David Pratt Posted June 23 Share Posted June 23 The Monaco Part Number is #16620608 and the vendor part number is #46081CT804. I have included a couple of vendors you might try, go here; https://www.unityparts.com/led-back-up-lamps/ https://www..com/ truck-lite products/lights/back-up-lights.html?_=1719158563849&p=5&ajaxscroll=1 Amazon would also be a place to look. Link to comment Share on other sites More sharing options...
Donflem Posted 23 hours ago Share Posted 23 hours ago M4 system in calif Link to comment Share on other sites More sharing options...
