vanwill52 Posted June 20 Share Posted June 20 I'm about to go on a 4-hour errand, so I wanted to post this before leaving. I'll return this afternoon. I'm planning to leave on a trip tomorrow morning. I have a 35 code, which simply says "Needs Service". Pressing the Start button from any of three locations does nothing. No click. No engine turn over. The lights---blink-blink-blink PAUSE blink-blink-blink-blink-blink, which I'm interpreting as Code 35. I'll work on it some more when I get back today. Van Williams 2000 Dynasty 36 ISC-350 Onan 7500 Quiet Diesel (inverter-type) Link to comment Share on other sites More sharing options...
jacwjames Posted June 20 Share Posted June 20 There are 3 fuses under the small access panel above the start button on the generator. I'd start checking those 3 fuses, I know one of them has to do with the starting function. I believe one is a 25 amp fuse and the others 10 or 15 amp. Link to comment Share on other sites More sharing options...
vanwill52 Posted June 20 Author Share Posted June 20 Thanks, Jim. I only saw two fuses under that cover. I'll look again. Both fuses good. Oil and coolant were OK. Disconnected/reconnected the multi-pin line going to the genny. Link to comment Share on other sites More sharing options...
jacwjames Posted June 20 Share Posted June 20 (edited) On mine two of the fuses were attached to the neck of the coolant fill, the other was loose. When my wife was trying to get her's going late last month she found the loose one but the others were attached to the neck and at first glance didn't see them while we were doing a Facetime call. Edited June 20 by jacwjames Link to comment Share on other sites More sharing options...
Ivan K Posted June 20 Share Posted June 20 I hate to even mention it but isn't code 35 for self check failure on the control board? Maybe try reseting the connector? Wish it's something easier and cheaper than that. 1 Link to comment Share on other sites More sharing options...
96 EVO Posted June 20 Share Posted June 20 17 minutes ago, Ivan K said: I hate to even mention it but isn't code 35 for self check failure on the control board? Maybe try reseting the connector? Wish it's something easier and cheaper than that. Would explain it not even attempting to start! Link to comment Share on other sites More sharing options...
Dr4Film Posted June 21 Share Posted June 21 @Ivan K is correct. C&P from the 7.5K Manual - CONTROL CARD FAILURE FAULT—CODE NO. 35 (Microprocessor EEPROM error during self-test) Corrective Action: See an authorized Onan dealer. Link to comment Share on other sites More sharing options...
Tom Cherry Posted June 21 Share Posted June 21 31 minutes ago, Dr4Film said: @Ivan K is correct. C&P from the 7.5K Manual - CONTROL CARD FAILURE FAULT—CODE NO. 35 (Microprocessor EEPROM error during self-test) Corrective Action: See an authorized Onan dealer. Ain’t but one call needed. FlightSystems.com. They are the experts on boards and board repairs and also refurbished replacements. They do, as of a member’s recent post, allow returns if issues other than the main board…. They also provide tech support to diagnose. Onan is good….these guys are better Link to comment Share on other sites More sharing options...
vanwill52 Posted June 22 Author Share Posted June 22 Thanks, everyone. I'm on my trip. Guess I just won't have a genny until I get home. Link to comment Share on other sites More sharing options...
96 EVO Posted June 22 Share Posted June 22 Well, hopefully you are traveling shore power to shore power. Link to comment Share on other sites More sharing options...
vanwill52 Posted June 22 Author Share Posted June 22 10 hours ago, 96 EVO said: Well, hopefully you are traveling shore power to shore power. Thanks! No other choice. Link to comment Share on other sites More sharing options...
