I need access to the back TV in my 2005 Beaver Patriot, it appears that the cabinet is made to open the face with the TV mounted on it by swinging to the right, I can't see any other access, but I can't see any release or means of opening, any suggestions would be appreciated, thanks!
Edited by Neil Loveless
add photo
Take off the four wooden "buttons" on the front wood trim, and that should reveal screws that can then be removed with should remove the wood "trim" piece around the TV.  I see what looks like possibly some wood "buttons" on the side of the trim piece that may also need to be removed to reveal additional screws.
  -Rick N.
You were correct, I was thinking the same thing but didn't want to damage the buttons to remove them without someone else thinking the same thing.  As it turned out I only had to remove one button (top left front), and the 4" screw it hid and the entire TV and frame swung out like a door, couldn't have been easier, thanks for the suggestion!
