CutGrass91 Posted Wednesday at 08:31 PM Share Posted Wednesday at 08:31 PM (edited) Hey everyone! You have all been a great help in my very intense journey so far. I have a 2001 Monaco Windsor PBD. I have 2 slides on my coach that do not extend. When I hit the button nothing happens, same with the bedroom slide. It sounds like it could be the fuse on the slide control board, HOWEVER, I cannot for the life of me find it. I'm adding a picture of the riveted diagram on my passenger rear electrical bay, as well as the actual image of the bay. As you can see, the slide control board is just not there. I saw another post that said his was in his inverter bay but it's not there either. Any suggestions are welcome. Edited Wednesday at 08:34 PM by CutGrass91 Link to comment Share on other sites More sharing options...
jacwjames Posted Wednesday at 08:40 PM Share Posted Wednesday at 08:40 PM Hmmmm In your first picture it actually shows the slide controller in the lower left and corner. But it's not in the actual compartment UNLESS that relay block on mounted on the lower left side. Can you take a picture of the other compartment next to the one you have a picture of. Link to comment Share on other sites More sharing options...
CutGrass91 Posted Wednesday at 08:43 PM Author Share Posted Wednesday at 08:43 PM Jacwjames, yes the riveted diagram shows the controller in the lower left hand corner. I'm not sure what is actually there but does not match up with the diagram. Link to comment Share on other sites More sharing options...
jacwjames Posted Wednesday at 08:58 PM Share Posted Wednesday at 08:58 PM My slide controller is mounted on the floor of the compartment Do you have a wiring diagram of your coach. My guess is the relay block on the mounted on the lower left side of the compartment. It looks like there is a wire coming from the salesman switch, this is where my controller gets its power. The rest of the wires are in a connector that connects to the control board. Look at your wiring diagram and see if the wiring matches the controller. The relays may do the same thing. Attached is the wiring for the relays. When you open it the lines will be blurry, hit CTRL5 and it will clear right up. You might see if the colors match the ones going to the relay block. 2002_Windsor_wiring_diagrams Rear Passenger side electric Slide relay wiring..pdf Link to comment Share on other sites More sharing options...
Tom Cherry Posted Wednesday at 09:32 PM Share Posted Wednesday at 09:32 PM 30 minutes ago, jacwjames said: My slide controller is mounted on the floor of the compartment Do you have a wiring diagram of your coach. My guess is the relay block on the mounted on the lower left side of the compartment. It looks like there is a wire coming from the salesman switch, this is where my controller gets its power. The rest of the wires are in a connector that connects to the control board. Look at your wiring diagram and see if the wiring matches the controller. The relays may do the same thing. Attached is the wiring for the relays. When you open it the lines will be blurry, hit CTRL5 and it will clear right up. You might see if the colors match the ones going to the relay block. 2002_Windsor_wiring_diagrams Rear Passenger side electric Slide relay wiring..pdf 111.67 kB · 4 downloads Page 236 of the manual (which is a farce for that year…3 pages of how to use a video switcher….and nary a word about the slide controller).. Circuit Breaker 1, is a 15 AMP. See if that has tripped or the lever is down. FROM MEMORY. BAY DOOR switches and park break switch must be made to even allow power to the elusive controller. Wish i had more. The Windsor manuals were not Monaco’s greatest achievement….. 1 Link to comment Share on other sites More sharing options...
CutGrass91 Posted Wednesday at 09:37 PM Author Share Posted Wednesday at 09:37 PM 2 minutes ago, Tom Cherry said: Page 236 of the manual (which is a farce for that year…3 pages of how to use a video switcher….and nary a word about the slide controller).. Circuit Breaker 1, is a 15 AMP. See if that has tripped or the lever is down. FROM MEMORY. BAY DOOR switches and park break switch must be made to even allow power to the elusive controller. Wish i had more. The Windsor manuals were not Monaco’s greatest achievement….. Agreed. There's an entire page dedicated to explaining how batteries work on a chemical level too. Unreal. I've checked that #1 spot already and does not seem to be the issue. Link to comment Share on other sites More sharing options...
jacwjames Posted Wednesday at 09:53 PM Share Posted Wednesday at 09:53 PM Try opening and slamming the doors under your front slide. I have one that the inhibitor switch doesn't close and the slide won't work. Open and slam it shut and it works. I looked at the 2000 Windsor wiring diagram and it also shows a slide controller so no telling what's going on with yours. I also have a generator slide that uses the same controller. Just for laughs you might check your front drivers side electrical bay and see if there might be two slide controllers in that compartment and/or what they might be using there. Link to comment Share on other sites More sharing options...
mdgabe Posted Thursday at 04:14 PM Share Posted Thursday at 04:14 PM From my personal experience...make sure all your compartment door safety switches are intact. I apparently hit one of mine and broke a wire, and the slide would not move causing a couple of harried days🤣 Link to comment Share on other sites More sharing options...
jacwjames Posted Thursday at 05:06 PM Share Posted Thursday at 05:06 PM The last time I had trouble with my slides it was also one of the inhibitor switches. From appearance it looked good. I tried everything to get the slides to work. The controller kept blowing the fuse. I finally removed the wiring harness from the slide controller and check each wire to ground and found the one for the door switches was grounded out. Started checking and when I felt the back side of one of the inhibitor switches it fell apart in my hand. I carried a spare so I replaced it and that solved the problem. Link to comment Share on other sites More sharing options...
CutGrass91 Posted Thursday at 05:09 PM Author Share Posted Thursday at 05:09 PM 1 minute ago, jacwjames said: The last time I had trouble with my slides it was also one of the inhibitor switches. From appearance it looked good. I tried everything to get the slides to work. The controller kept blowing the fuse. I finally removed the wiring harness from the slide controller and check each wire to ground and found the one for the door switches was grounded out. Started checking and when I felt the back side of one of the inhibitor switches it fell apart in my hand. I carried a spare so I replaced it and that solved the problem. Where would I find the inhibitor switch? I feel like my main issue is I just can't find my slide control board anywhere! Link to comment Share on other sites More sharing options...
mdgabe Posted Thursday at 05:41 PM Share Posted Thursday at 05:41 PM 29 minutes ago, CutGrass91 said: Where would I find the inhibitor switch? I feel like my main issue is I just can't find my slide control board anywhere! My basement compartment doors have plunger type switches up in the corner. Keeps the slide from opening when the door is open. When I broke the wire, the slide thought the door was open and wouldn't work. No clicking, nothing, just wouldn't open until I fixed the broken wire... Link to comment Share on other sites More sharing options...
CutGrass91 Posted Thursday at 10:49 PM Author Share Posted Thursday at 10:49 PM 5 hours ago, mdgabe said: My basement compartment doors have plunger type switches up in the corner. Keeps the slide from opening when the door is open. When I broke the wire, the slide thought the door was open and wouldn't work. No clicking, nothing, just wouldn't open until I fixed the broken wire... Possibly, I'll have to check all the switches but they all seem to be fine at first glance. I'll take a multimeter to them when I get home and ensure they're functional. Link to comment Share on other sites More sharing options...
jacwjames Posted Friday at 12:00 AM Share Posted Friday at 12:00 AM 1 hour ago, CutGrass91 said: Possibly, I'll have to check all the switches but they all seem to be fine at first glance. I'll take a multimeter to them when I get home and ensure they're functional. You can jump each one out and if the slide works that's your problem. Link to comment Share on other sites More sharing options...
CutGrass91 Posted Friday at 12:01 AM Author Share Posted Friday at 12:01 AM Just now, jacwjames said: You can jump each one out and if the slide works that's your problem. Maybe a stupid question but do you guys make your own jumpers or by them somewhere? Link to comment Share on other sites More sharing options...
Ivan K Posted Friday at 12:18 AM Share Posted Friday at 12:18 AM If these switches have flat spade connectors, jump them with a flat automotive fuse, like in your spares. Link to comment Share on other sites More sharing options...
Dr4Film Posted Friday at 01:30 PM Share Posted Friday at 01:30 PM I made up jumpers for every door that had a plunger type switch. I was tired of having temporary problems with those switches. Of course, you have to be cognizant of NOT moving the slide with one of those bay doors under the slide adjusted to WIDE OPEN. My guess is that those three relays control your two slides. One of the three relays is your ignition lockout relay. Link to comment Share on other sites More sharing options...
