Pogo3979 Posted Monday at 01:02 AM Share Posted Monday at 01:02 AM Anyone know the part # of a 2007 isl 400 Cummins starter. It has a leece Neville starter and is not available. Link to comment Share on other sites More sharing options...
klcdenver Posted Monday at 02:07 AM Share Posted Monday at 02:07 AM In the IRV2 Monaco owners forum search for this forum "ISL 400 Starter Issue". It discusses changing to a Delco . I have also attached the Delco info. Keep us posted on your fix please. I have the same year engine. Kenneth Starter.pdf Link to comment Share on other sites More sharing options...
Benjamin Posted Monday at 05:16 AM Share Posted Monday at 05:16 AM (edited) 8200433 Delco, you may have to "clock" the starter, that is, rotate the housing from the nosepiece by removing bolts and rotating to fit your application/match the old starter, then test fitting, then tightening all the bolts. But the gear reduction starter is 30 pounds, compared to over 50 for a direct drive, so much easier to handle. It takes a 12point, 12mm socket if you have the funny bolts. And a bunch of extensions and wobbles to get the old one off. New one goes on easier. Edited Monday at 05:18 AM by Benjamin Link to comment Share on other sites More sharing options...
