jd4714 Posted July 1 Share Posted July 1 I have a 1994 Monaco Dynasty which all the dash gauges except for the speedo, turbo boost and air pressure gauge work intermittently. When the gauges go out the Pac brake, jacks and 12V outlet also don't work. Initially when I hit a bump they would come back on but now a bump in the road does nothing. Any thoughts? Link to comment Share on other sites More sharing options...
Dr4Film Posted July 1 Share Posted July 1 (edited) Bad ground connection. Redo all of your connections making sure there is no corrosion and the connection is clean and solid. Start at the front and work your way towards the rear. Edited July 1 by Dr4Film Link to comment Share on other sites More sharing options...
jd4714 Posted July 1 Author Share Posted July 1 3 minutes ago, Dr4Film said: Bad ground connection. Start at the front and redo all of your connections making sure there is no corrosion and the connection is clean and solid. Thank you for the fast response! Link to comment Share on other sites More sharing options...
klcdenver Posted July 1 Share Posted July 1 Probably bad ground as Dr4Film said. Sometimes hard to find and just easier to run a new ground wire. Link to comment Share on other sites More sharing options...
jd4714 Posted July 1 Author Share Posted July 1 Thank you. Link to comment Share on other sites More sharing options...
