2000 Dynasty Framing Photo
Posted (edited)
Found my old infrared camera today after it went “missing” for year and a half.  Had to play with it a bit yesterday evening.
This photo is the side of our 2000 Dynasty York showing the warmer framing beneath the fiberglass skin.
Edited by Jim Pratten
I wish they had been around years ago as there are so many uses for them. Last week workin on a 1995 moho the customer complained there water pump wouldnt shut off a quick scan of circuits an fuses shows a old style glass buss fuse takin a beating fom loose fit an more amps that it should handle.IMG_5862.thumb.jpeg.3dfd25570cd38d925c412f380befdc15.jpeg
That is a great tool to have if you plan to install an outside exhaust port for the microwave making sure you don't have a metal sidewall frame member in your way.
I took a photo of my sidewall frames when it was cool outside and the dew had settled on the fiberglass indicating where the frame members were located.
I did that same thing however just got the driver side.
I use a similar IR camera attached to my cell phone to spot hot locations indicating poor connections/failed components on circuit boards or loose high current low voltage battery connections.  Actually a whole lot easier than measuring voltage drop to spot a poor high current / low voltage connections.
  • Like 2
Great application Frank.
My most memorable use of IR was a roofing survey of the complex looking for compromised roofs. Flew in a helicopter at sundown, taking IR photos of the built up roofs. The damaged areas typically trapped water with those areas showing up darker. Good fun.
Couldn't resist, had to buy the new toy.  First up was side shot of the RV, but only get a glimpse of morning sun before it goes in the shade.  Unfortunately the IR lens doesn't allow zooming, and I had a stack of bushes behind me so could only catch a corner.
It also worked for checking propane level (1/4 tank), heat leakage around the fridge, battery temps (coach batt +4F vs chassis batt).  Next trip I'll use it to look for leaks around the front end.
The FLIR was much lower resolution so ended up getting the Topdon TC001 from Amazon
TOPDON TC001 Thermal Imaging Camera . . . check out the resolution of the neighbor's tractor.
- bob
