JustaRamble Posted July 11 Share Posted July 11 2000 HR Ambassador. What's the ID size and length of the fuel fill hose to tank? In search I found where someone posted they thought it was 2", but I'd like to be sure, along with the length so I can order the right hose. Thanks! Link to comment Share on other sites More sharing options...
jacwjames Posted July 11 Share Posted July 11 (edited) What hose is this, is this one that goes to the fuel tank??? Is so just remove and take it to an Auto parts store In not look at the hose going to primary filter, this will be the fuel supply from the tank. Length will depend on how long your coach is and routing. You might see if you can pull the old hose from either direction. Slim chance that you might be able to pull a new hose using the old one. You can buy fuel hose by the foot. On mine the ends are JIC type and they are crimped on. You can buy field fit type JIC fitting so you can install on a new hose. https://valvehalla.com/products/reusable-jic-female-hose-tail-for-sae100r2-hydraulic-hose shop around for the best prices. Edited July 11 by jacwjames Link to comment Share on other sites More sharing options...
JustaRamble Posted July 11 Author Share Posted July 11 19 minutes ago, jacwjames said: What hose is this, is this one that goes to the fuel tank??? Is so just remove and take it to an Auto parts store In not look at the hose going to primary filter, this will be the fuel supply from the tank. Length will depend on how long your coach is and routing. You might see if you can pull the old hose from either direction. Slim chance that you might be able to pull a new hose using the old one. You can buy fuel hose by the foot. On mine the ends are JIC type and they are crimped on. You can buy field fit type JIC fitting so you can install on a new hose. https://valvehalla.com/products/reusable-jic-female-hose-tail-for-sae100r2-hydraulic-hose shop around for the best prices. It's the fuel filler hose. Just asking if someone knew because I could order what I need in advance instead of having to take it off and go to auto parts store. Link to comment Share on other sites More sharing options...
dl_racing427 Posted July 13 Share Posted July 13 On 7/11/2024 at 2:59 PM, JustaRamble said: It's the fuel filler hose. Just asking if someone knew because I could order what I need in advance instead of having to take it off and go to auto parts store. These vehicles are basically hand made. I wouldn't be surprised to find different length hoses from one coach to another of the same model. Best method is to compare to what you have. Link to comment Share on other sites More sharing options...
