96 EVO Posted August 5 Share Posted August 5 Good to hear you got it sorted 👍! Link to comment Share on other sites More sharing options...
Romeo84 Posted August 5 Share Posted August 5 So funny think I'm going through the same thing.... pump turns no air lock. I did have a kink when slide was closed it would bend the hose but still can find why it's not pushing fluid through Link to comment Share on other sites More sharing options...
flimmy Posted September 28 Share Posted September 28 On 7/26/2024 at 12:43 AM, Frank McElroy said: In effect you have 2 front heat exchangers both fed by the same AquaHot circulating pump zone. If the circulating pump is working, the problem is almost always a stuck check valve after the pump on that loop. With the circulating zone pump running, give the check valve a few sharp raps with a hammer or crescent wrench and I'll bet you an adult beverage that hot water will start flowing. Frank , where are the valves located ? I have an 04 Dynasty. Thanks Link to comment Share on other sites More sharing options...
Frank McElroy Posted September 28 Share Posted September 28 15 minutes ago, flimmy said: Frank , where are the valves located ? I have an 04 Dynasty. Thanks They are just under the AquaHot cover - see page 9 in the attached file link. AHE-100-03S_AHE-120-03X_AHE-130-03X_Parts_Manual_REV_C._01-2013.pdf 1 Link to comment Share on other sites More sharing options...
flimmy Posted September 28 Share Posted September 28 Thank you Link to comment Share on other sites More sharing options...
