overworked tech Posted August 12 Share Posted August 12 I have a 2004 Diplomat The headlight assembly is from a late nineties early 2000 Buick regal/ century vehicles. I am about to change out the assembly with newer clean ones to freshen up the front end . Has anyone replaced with the custom black assembly they offer over the chrome look of the original. Would like to see pictures if you have them after the swap. Buick Century/Regal OE Replacement Black Bezel Headlights Driver/Passenger Head Lamps Link to comment Share on other sites More sharing options...
MyronTruex Posted August 12 Share Posted August 12 While you are at it, I suggest you measure the headlight voltage before you make the change. If you have low voltage due to weak wiring a simple relay kit can be installed and this would be a great time to accomplish both tasks. Link to comment Share on other sites More sharing options...
