Owen Poole Posted September 1 Share Posted September 1 2008 Monaco Diplomat 400isl with rear radiator, best way to replace water pump Link to comment Share on other sites More sharing options...
PeterSchweizer Posted September 1 Share Posted September 1 Easiest way is to drop it off n pay somone to do it, ha ha!! Seriously if you are mechanicaly inclined, removing a Radiator is not that hard, just need someone to help lift it out after removing stuff, draining coolant, replace ALL ENGINE N RADIATOR Hoses, t stat Radiator cap etc. Have Radiator professionally flushed n pressure tested at big rig truck Radiator shop while out replace belts etc also may want to flush n test CAC, replace hoses check turbo.... Link to comment Share on other sites More sharing options...
klcdenver Posted September 2 Share Posted September 2 It would be pretty hard to reach without pulling radiator. If you have long arms you might get to it by removing the bedroom and closet hatches. This picture is an ISL 400 from my 2007 Diplomat. I just replaced my CAC, radiator, alternator, water pump, belt, transmission cooler and hoses. Link to comment Share on other sites More sharing options...
Benjamin Posted September 2 Share Posted September 2 If you're not intending to replace anything else, besides the belt and tensioner, then you can try from the side or top, I don't know the layout of that model. I had enough room to easily remove the water pump, but I already had a bolt missing, broken off, so I took the radiator and CAC off and still fought that bolt way longer than it should have, eventually tapped it to the next bigger size! It's an o ring seal and three bolts, so no gasket scraping or form a gasket involved. As long as the bolts break loose, it shouldn't be too bad. Link to comment Share on other sites More sharing options...
Owen Poole Posted Sunday at 11:41 PM Author Share Posted Sunday at 11:41 PM Decided to let shop fix it, he went from underneath and removed it, about 4 hours, thanks for all the suggestions Link to comment Share on other sites More sharing options...
