Bobkat11208 Posted September 3 Share Posted September 3 Replaced with BlueFire. Allows you to monitor, measure, track, and diagnose/reset Diesel engine codes. Works off of ECM and includes 6-9 pin connector for older J1708 protocol units. If you are not familiar, you can read more about it at https://www.scangauge.com/products/scangauge-d/ New ranging from $150-200+. $100.00 including shipping. Link to comment Share on other sites More sharing options...
Solution Just Jim Posted September 3 Solution Share Posted September 3 Hey Bob, If no one else has responded, I'll buy it. I am in the middle of building a house and I'm not going to have time to mess with the blue fire any time soon, Link to comment Share on other sites More sharing options...
scottknight Posted September 4 Share Posted September 4 just starting to look at this, could have used it on a couple of summits on last trip. Reason for change to BlueFire? ..... 04 8.3 330hp Link to comment Share on other sites More sharing options...
c210pa18 Posted September 4 Share Posted September 4 I very much like having them both the ScanGauge and BlueFire. I normally have the ScanGauge set to read out TODAYS data which resets its self daily so you can just scroll through miles today, fuel today, milage today etc. You could also do this with BlueFire but it just works nice to have them both. even if some of the data can be redundant. I was going to sell mine too but I am glad to have both working together.d 1 Link to comment Share on other sites More sharing options...
Bobkat11208 Posted September 4 Author Share Posted September 4 (edited) 2 hours ago, scottknight said: just starting to look at this, could have used it on a couple of summits on last trip. Reason for change to BlueFire? ..... 04 8.3 330hp I chose the Bluefire primarily for the reason that I don't trust the 20+ YO analog gauges (which is the exact same reason I initially went with the ScanGauge-D). Plus, the SG, while it was very useful, and honestly reads the same data off the ECM, only presented 4 data points at a time and I'm more of a visual person. So there was both a function & form component to my decision to switch. If I had never heard of the BlueFIre, I'd still be using the SG today. However, being a mechanical engineer and a tech/IT guy, I have to admit it's also kinda neat to have a 'Glass Dash'; i.e. a single point to monitor what I consider critical data. Make sense? Bottom line-I would recommend either. Edited September 4 by Bobkat11208 Added comment Link to comment Share on other sites More sharing options...
