Greg Coffey Posted yesterday at 02:39 PM Share Posted yesterday at 02:39 PM My auto leveling control pad is wearing out it seems. The raise button needs to be played with for awhile before I can get a connection. All other buttons work fine. I am having trouble finding the proper replacement as my part numbers don’t match up anywhere. Has anyone seen one such as the one in the photo? Thanks Link to comment Share on other sites More sharing options...
DavidL Posted yesterday at 02:42 PM Share Posted yesterday at 02:42 PM If particular switches are not working, likely due to grit getting inside due to the membrane being broken, they are readily available on Amazon. A Quick remove / resolder and they will be like new again. Somewhere I posted this exact procedure and links.... Link to comment Share on other sites More sharing options...
Greg Coffey Posted yesterday at 02:47 PM Author Share Posted yesterday at 02:47 PM Thank you David, I had looked through the articles and forums here and did not see the procedure. I will look again to see your post. Link to comment Share on other sites More sharing options...
Solution Ivan K Posted yesterday at 03:02 PM Solution Share Posted yesterday at 03:02 PM Greg, here is one of the related posts https://www.monacoers.org/topic/7994-hwh-computerized-leveling-panel/?do=findComment&comment=83018 Link to comment Share on other sites More sharing options...
Greg Coffey Posted yesterday at 05:38 PM Author Share Posted yesterday at 05:38 PM Thanks for the information and your time,,, much appreciated. I will open it up again and have another look at it. I will double check connections and clean it up a bit ,, see if it helps. Thanks Link to comment Share on other sites More sharing options...
RIPPPA Posted yesterday at 08:31 PM Share Posted yesterday at 08:31 PM Greg this keypad looks very similar to mine being in 2005 Dynasty. I called NW parts about it and they checked and said this model will need to be send to HWH to be rebuilt as this model is not available any longer. I’ll be sending mine to HWH in Oct when I get my coach back home to Texas. I would call HWH and see what they say. Be patient as they can be slow to return calls and emails. Good Luck. 2 Link to comment Share on other sites More sharing options...
Greg Coffey Posted yesterday at 11:13 PM Author Share Posted yesterday at 11:13 PM Thanks Tim, I'll be looking at a rebuild as well. Link to comment Share on other sites More sharing options...
beemerman Posted 9 hours ago Share Posted 9 hours ago I have a 2003 Dynasty and was having trouble with the leveling system. I sent the control panel and box to HWH to be checked out. It was relatively inexpensive and they put a new cover on the panel. Both components checked out ok and they just charged me a small fee for the cover and their time. The problem turned out to be the cable between the two. I would recommend having a HWH dealer send the panel to HWH because they are more responsive to their dealers. 1 Link to comment Share on other sites More sharing options...
Ivan K Posted 9 hours ago Share Posted 9 hours ago You can also buy and replace the sticker yourself. Mine was around $12 few years back. HWH refered to it as a lexan, I believe. Makes it look new. 1 Link to comment Share on other sites More sharing options...
