trstaska Posted yesterday at 04:52 PM Share Posted yesterday at 04:52 PM My Michelin's are 6 yrs old and I tried purchasing 275/80R22.5 XLEZ through the FMCA Michelin advantage program but they are back ordered. I considered XZE but they are backordered and I've heard they might have sidewall problems. I am considering Toyo but I can't find them in 275/80. Do they make 275/80 LRH? I'm told that I can use 295/75 instead. Is that right? Does changing sizes screw up the speedometer/odometer? I am only getting new Drives, we replaced the Steers last Fall. We have always had Michelins, we put about 10,000 miles per year on the MH and we don't mind spending the extra money for Michelin's if we can get them. What's the general advice? Link to comment Share on other sites More sharing options...
Solution hex_nut Posted yesterday at 08:40 PM Solution Share Posted yesterday at 08:40 PM The Toyo M154 295/75 has a diameter of 40.4 inches and a width of 11 inches. The Michelin 275/80 has a diameter of 40.2 and a width of 11.1. So, the two tire sizes are basically identical and would cause no significant change for your speedometer. I am running Toyo's and have been very happy with them. Richard 1 Link to comment Share on other sites More sharing options...
Scotty Hutto Posted 20 hours ago Share Posted 20 hours ago I have a 2006 Diplomat and I’m on my second set of Toyo 295/75R22.5 tires. The first were M177s, the current set are M154. Next set will likely be M177 if I can find them; my perception is they rode a little smoother… Roughly 70,000 miles over 7+ years and zero problems. Link to comment Share on other sites More sharing options...
Ivan K Posted 11 hours ago Share Posted 11 hours ago 19 hours ago, trstaska said: Does changing sizes screw up the speedometer/odometer? I am only getting new Drives, we replaced the Steers last Fall. Drive tire size change does effect speedometer and consequently odometer. You can get an idea of percentage of change by comparing values of 'rotations per mile' which is in every manufacturers table I have seen. Link to comment Share on other sites More sharing options...
Paul J A Posted 7 hours ago Share Posted 7 hours ago Consider 11r 22.5 for the Drive, AND Tag axle when applicable too. They exceed the Axle Weight ratings and save $$$. 1 Link to comment Share on other sites More sharing options...
