Tom Cherry Posted 6 hours ago Share Posted 6 hours ago Frank is correct. YES….it MORPHED. Suggested that one could use SeeLevel sensors. These are LONG printed circuit boards….capacitance measurement….not compatible with TECMA. Tecma has, print was posted way earlier, TWO sensors that are specifically designed (Inductive) and MUST be used to make their controls work. Frank posted a resistor value to “fake out” or make the Tecma say…ALL IS WELL. DANGER..if the tank is full….big problems….read the posts. THEN…it morphed into, well Tecma might be working….but the idiot lights are still off. The IDIOT Lights are powered by probes that are bolted and sealed to the sidewall of the tank. They make an electrical circuit. Not connected nor integrated or anyhow REMOTELY connected to the OP’s Tecma. Right now….this is a “Black Tank Maintenance and Sensor Information - 101”. Too many have too little knowledge of the issues (crap on interior walls of black tank) and how SeeLevel is totally different from the Probe style or OEM Monaco…. Tecma is a “standalone” system and has to have its OWN level or alarm “stick on outside” sensors….that read in OHMS via an inductive method….not Capacitance. If Pop Quiz is given, most likely heavily graded on the curve. BUT…the issue of Black Tanks and measurement snd such are all interrelated… Link to comment Share on other sites More sharing options...
Bobbyboy Posted 4 hours ago Share Posted 4 hours ago 2 hours ago, Frank McElroy said: Tecma has its own two sensors that stick onto the side of the tank. Thanks Frank; my confusion is solved. Bob L Link to comment Share on other sites More sharing options...
