Jims rv diesel heater repa Posted Monday at 12:30 PM Share Posted Monday at 12:30 PM Aqua-hot leaking coil alternative 2 Link to comment Share on other sites More sharing options...
Dr4Film Posted Tuesday at 02:59 PM Share Posted Tuesday at 02:59 PM @Jims rv diesel heater repa Thank you SO much for sharing your expertise and your custom built heat exchanger device for replacing a failed fresh water Aqua-Hot coil whether it be an internal or external one. If mine were to fail, you will be my FIRST call! Link to comment Share on other sites More sharing options...
Jims rv diesel heater repa Posted Tuesday at 05:00 PM Author Share Posted Tuesday at 05:00 PM Ok thanks the exchanger works great unlimited hot water.Just need a place to mount.Last job I did we mounted in storage bay on wall ran connections through wall to unit. Link to comment Share on other sites More sharing options...
Dr4Film Posted Tuesday at 05:57 PM Share Posted Tuesday at 05:57 PM (edited) Yes, in thinking about the size of your device, the biggest challenge is finding a convenient location to mount it. Hopefully, I won't have to need one. But if I do, I know exactly who to call. Edited Tuesday at 05:57 PM by Dr4Film Link to comment Share on other sites More sharing options...
Jims rv diesel heater repa Posted Tuesday at 06:11 PM Author Share Posted Tuesday at 06:11 PM You could put equipment in different locations ,but it would be hard to trouble shoot.With this board it would be easy to check ,if Aquahot is up to temp and you have no hot water you go to this board. Coils usually don’t start leaking for no reason ,most of time it is freeze ups,not winterized correctly Link to comment Share on other sites More sharing options...
