Steve and Callie Posted Thursday at 06:48 PM Share Posted Thursday at 06:48 PM I have a 2005 Monaco 40 DST. Having an alignment done. Owners manual shows the following specs, would like to confirm these are still accurate. If you know of an alignment shop that is good we these, their information would be appreciated. Thank you. Camber Front Spec. 0.00 Tol. 0.40. Rear Spec. -0.25. Tol. 0.40 Caster. Front Spec. 6.00 Tol. 0.50. Rear Spec. 6.00. Tol. 0.50 Toe. Front. Spec. 0.03. Tol. 0.12. Rear. Spec. 0.03. Tol. 0.12 Link to comment Share on other sites More sharing options...
Dr4Film Posted Thursday at 07:27 PM Share Posted Thursday at 07:27 PM Don't know anyone in Minot ND. You're out there in the boonies! Link to comment Share on other sites More sharing options...
Steve and Callie Posted Thursday at 07:49 PM Author Share Posted Thursday at 07:49 PM I was looking for anywhere, if nothing else, I can call for guidance. Thank you. Link to comment Share on other sites More sharing options...
Solution Dr4Film Posted Thursday at 07:56 PM Solution Share Posted Thursday at 07:56 PM (edited) Steve, one of the most prestigious chassis shops in the country is Josam in Orlando. Henderson's Alignment in Oregon is also right up there. Josam - https://josamusa.com/ Henderson's - https://www.hendersonslineup.com/ Edited Thursday at 07:56 PM by Dr4Film Link to comment Share on other sites More sharing options...
Steve and Callie Posted Thursday at 07:58 PM Author Share Posted Thursday at 07:58 PM Thank you Link to comment Share on other sites More sharing options...
timaz996 Posted Thursday at 08:06 PM Share Posted Thursday at 08:06 PM Before doing an alignment make sure your six pack valves don't have any leaks. A 10% leak in a couple of valves can twist the chassis and make it feel like it's out of alignment. It happened to me. 1 Link to comment Share on other sites More sharing options...
Dr4Film Posted Thursday at 08:16 PM Share Posted Thursday at 08:16 PM The 6 pack valves except for the two on the top which are for Ride Height are not in the equation while aired up to Ride Height and driving. Please explain how your 6 pack affected your alignment unless you are stating that your ride height was off? Link to comment Share on other sites More sharing options...
Steve and Callie Posted Thursday at 08:36 PM Author Share Posted Thursday at 08:36 PM Will be checking ride height, will check for leaks at the same time. Thank you. 41 minutes ago, Dr4Film said: Steve, one of the most prestigious chassis shops in the country is Josam in Orlando. Henderson's Alignment in Oregon is also right up there. Josam - https://josamusa.com/ Henderson's - https://www.hendersonslineup.com/ Contacted Berry at Josam, very knowledgeable and helpful. Thank you. Link to comment Share on other sites More sharing options...
timaz996 Posted yesterday at 12:01 AM Share Posted yesterday at 12:01 AM 3 hours ago, Dr4Film said: The 6 pack valves except for the two on the top which are for Ride Height are not in the equation while aired up to Ride Height and driving. Please explain how your 6 pack affected your alignment unless you are stating that your ride height was off? I know they are not in play, but if they leak they will give you a problem. You can look up my post on irv2 from about five years ago to see how many people are misinformed about this. Link to comment Share on other sites More sharing options...
Tom Cherry Posted yesterday at 12:14 AM Share Posted yesterday at 12:14 AM 3 hours ago, Steve and Callie said: Will be checking ride height, will check for leaks at the same time. Thank you. Contacted Berry at Josam, very knowledgeable and helpful. Thank you. BARRY... NOT Berry.... YES....he is a GREAT resource. He will discuss and tell you specs... he has provided us with front end data and specs as well as the RIDE HEIGHT setting for many coaches. 1 Link to comment Share on other sites More sharing options...
