Cajunboy1959 Posted Friday at 08:06 PM Share Posted Friday at 08:06 PM (edited) Where to purchase radiator hodes for a 2004 Safari Cheetah 38PDQ Catapilar C7 engine. I have called Catapilar, local truck repair, NAPA, etc No luck. Does anybody know of where to get these? Edited Friday at 08:06 PM by Cajunboy1959 Link to comment Share on other sites More sharing options...
Chargerman Posted Friday at 08:22 PM Share Posted Friday at 08:22 PM I don’t have the same coach but when I replaced all of mine I got the diameters and dims off the old ones and went to NAPA. They had a book with all of the pre-bent hoses. I was able to find matches or ones that I could cut a section from to replace all of the hoses. Link to comment Share on other sites More sharing options...
Benjamin Posted Saturday at 12:48 AM Share Posted Saturday at 12:48 AM I used summit racing, they have a great search feature that will search by inner diameter for straight hoses or bends. For hoses that may be specific off the water pump or thermostat, search for a truck of similar year with that engine, I did that for the water pump inlet hose on my cummins that is specific to the cummins. Link to comment Share on other sites More sharing options...
Solution Mark C Posted Saturday at 01:08 PM Solution Share Posted Saturday at 01:08 PM I used a Gates Rubber catalog to find replacement hoses for my engine by using diameter measurements and the photos in the catalog. I had to shorten a couple of them, but that was easy and it solved the issue. Link to comment Share on other sites More sharing options...
Chargerman Posted Saturday at 01:23 PM Share Posted Saturday at 01:23 PM I think that the same catalog that I used. 👍👍 Link to comment Share on other sites More sharing options...
KenBob Posted Saturday at 02:06 PM Share Posted Saturday at 02:06 PM Got the straight ones from Amazon the Bent ones from Advanced Auto parts Link to comment Share on other sites More sharing options...
Agpopp Posted Saturday at 02:48 PM Share Posted Saturday at 02:48 PM From my post history.... Would have been nice to find this earlier! Not sure how accurate it it's but seems legit based on my 06 Neptune hoses. Check it out...... Use the application tab, heavy duty and put in your coach! https://na.daycoaftermarket.com/en/applications/automotive/#page=application https://www.monacoers.org/topic/6383-dayco-hose-and-belt-resource/?do=findComment&comment=62727 Link to comment Share on other sites More sharing options...
