scott truelove Posted Sunday at 01:29 PM Share Posted Sunday at 01:29 PM The alternator is putting out 24 v Does it have a built in regulator that can be replaced? The other picture i think has been fried. Can it be replaced? I don’t know what it is called My cell is 8127091132 thank you in advance Link to comment Share on other sites More sharing options...
Ivan K Posted Sunday at 01:48 PM Share Posted Sunday at 01:48 PM The regulator is the part with green sticker in you second picture. A good alternator shop can rebuild the whole thing with good genuine parts. 1 Link to comment Share on other sites More sharing options...
Benjamin Posted Sunday at 01:56 PM Share Posted Sunday at 01:56 PM The blue finned aluminum thing is a diode battery isolator. The alternator output is connected to the center post, the house battery is one end, and the chassis battery is the other end. That is a DUVAC system. The alternator has a "remote sense" terminal (that might be labeled "DUVAC") that has to be connected to the chassis battery to control the voltage. You can run an extra test wire from the remote sense/duvac terminal to the positive terminal of the chassis battery, or the starter terminal, or that diode terminal, or even the big B+ terminal on the alternator, and check the voltage again. OR, you could use the wire to check the voltage at the remote sense terminal while the alternator is running. Where are you reading 24V? if everything has been reasonably charged, and the engine is running, that diode isolator should have about 15v in the middle, and about 14v to both battery banks. Link to comment Share on other sites More sharing options...
Paul J A Posted yesterday at 01:20 AM Share Posted yesterday at 01:20 AM (edited) Don't know if a Lambert 415 will work. https://rvaccessories.visonerv.com/cgi-bin/md/M200084/s3.pl Or these; https://www.google.com/search?q=diode+isolator&rlz=1C1CHBF_enUS1020US1020&oq=Diode+isolator&gs_lcrp=EgZjaHJvbWUqDQgAEAAYkQIYgAQYigUyDQgAEAAYkQIYgAQYigUyCAgBEAAYFhgeMgoIAhAAGA8YFhgeMggIAxAAGBYYHjIICAQQABgWGB4yCAgFEAAYFhgeMggIBhAAGBYYHjIICAcQABgWGB4yCAgIEAAYFhgeMggICRAAGBYYHtIBCTkyNjdqMGoxNagCCLACAQ&sourceid=chrome&ie=UTF-8 Edited yesterday at 01:24 AM by Paul J A Link to comment Share on other sites More sharing options...
RVerBob Posted yesterday at 12:27 PM Share Posted yesterday at 12:27 PM I see you have a Indiana number, Vans Electric can rebuild. Some times same day,but more likely next day Link to comment Share on other sites More sharing options...
