dandick66 Posted Sunday at 02:45 PM Share Posted Sunday at 02:45 PM While looking for air leaks, I discovered the wet side of the front tank is leaking at the weld seam. It’s a little difficult to see in the picture, but you can hear it and feel it with your hand. I am either going to buy a new one, or get this welded. I have an email into REV for pricing and availability of a new tank. I looked in the parts list and did not see it listed. I’ve done a little bit of web searching and haven’t had success. I would imagine that Monaco used the same tanks for years. Has anyone else had this problem? Is this safe to weld? Does anyone know of a source for a new one? Link to comment Share on other sites More sharing options...
timaz996 Posted Sunday at 03:37 PM Share Posted Sunday at 03:37 PM My "guess" would be if you weld it another leak will not be far behind. Link to comment Share on other sites More sharing options...
Walker Posted Sunday at 05:09 PM Share Posted Sunday at 05:09 PM I would use a camera to inspect the inside of the tank. If it's rusted out, replace it. If it looks good, I'd weld it up. I would try to determine the cause of the crack. 1 Link to comment Share on other sites More sharing options...
Bootlegger 659 Posted 4 hours ago Share Posted 4 hours ago Air tanks fill with condensation that is most likely the wet. Condensation (moisture) creates rust than pin holes. Every vehicle that has air brakes has an air supply tank. You can find these tanks at your local truck parts store or a reputable truck repair shop. Take your old tank in and they will fix you up. if you don't feel you are able take it to a truck repair shop and they will do it for you. Nothing special about it. Hope this gives you some encouragement. 1 Link to comment Share on other sites More sharing options...
