TANDD2 Posted yesterday at 12:00 AM Share Posted yesterday at 12:00 AM It appears that over the past 2.5 years in storage my 4 L16 house bank batts have been fried. I watered every month; seemed to take more as time went by. When I pulled it out of covered storage , where it was on 115 volts with Freedom invertor on, they would not hold a charge. Voltage out of charger was over 14 at float. It was suggested that I unplug the temp sensor and see what resulted. By this time I had determined batts were fried so I replaced them. with new batts charge voltages are normal and drop down to 13.5 at float as it should. Now the question, how beneficial is temp compensation and should I replace temp sensor? THX TANDD 2002 HR Endeavor 40 ISC 330 Link to comment Share on other sites More sharing options...
vito.a Posted yesterday at 04:04 AM Share Posted yesterday at 04:04 AM I doubt the battery temp sensor is the cause for your fried batteries. It is just a nice to have and not mandatory. You need to read your inverter manual and make sure it's set up properly for the type of batteries you have. Link to comment Share on other sites More sharing options...
