SteveHebe Posted 22 hours ago Share Posted 22 hours ago Well, I knew it would happen, I was hoping not so soon. I have owned my 2005 Diplomat 40PDQ since Sept 24. Yesterday while moving it around I caught the edge of my house and damaged a 6”-8” section of the side right below the Awning. What would you suggest I do to repair/minimize any further damage? TIA 2 Link to comment Share on other sites More sharing options...
DavidL Posted 21 hours ago Share Posted 21 hours ago If that gash is in fiberglass and there is no puncturing, you don't need to do anything. Will require sanding, body filler, sanding, cleaning, masking, priming, painting, clear coat. the Gutter can be banged out with body tools. I did same this summer backing up and clocked my gutter. Not quite as mangled as yours, but fixed in about an hour. No one knows now 🙂 1 1 Link to comment Share on other sites More sharing options...
Benjamin Posted 20 hours ago Share Posted 20 hours ago Might take an hour on each. I'd try buffing the fiberglass, it will easily be 90% better with an hours work, maybe five minutes? The gutter is thin aluminum, if you're handy with a hammer and a couple blocks of wood, it will be NEARLY invisible with a little work. If you're not handy, get somebody to straighten it out if it matters to you, don't end up like this: 2 Link to comment Share on other sites More sharing options...
DavidL Posted 11 hours ago Share Posted 11 hours ago I don't think the fiberglass gash will buff out....looks way too deep. Needs paint. 1 Link to comment Share on other sites More sharing options...
redstickbill Posted 9 hours ago Share Posted 9 hours ago Any good auto body shop can do the repairs to the coach at not much cost, including the proper paint matching. I just picked up my coach yesterday from the shop, I had several places repaired and repainted. Bill B 07 Dynasty Link to comment Share on other sites More sharing options...
dl_racing427 Posted 7 hours ago Share Posted 7 hours ago 14 hours ago, DavidL said: If that gash is in fiberglass and there is no puncturing, you don't need to do anything. Will require sanding, body filler, sanding, cleaning, masking, priming, painting, clear coat. the Gutter can be banged out with body tools. I did same this summer backing up and clocked my gutter. Not quite as mangled as yours, but fixed in about an hour. No one knows now 🙂 Ha, we ALL know now. 🤣🤣🤣😉 15 hours ago, SteveHebe said: Well, I knew it would happen, I was hoping not so soon. I have owned my 2005 Diplomat 40PDQ since Sept 24. Yesterday while moving it around I caught the edge of my house and damaged a 6”-8” section of the side right below the Awning. What would you suggest I do to repair/minimize any further damage? TIA Sorry to hear that, but it could've been worse. Fortunately, it's all in one color, so it should be pretty simple for a good body shop to repair. Be careful when maneuvering around obstacles, a lookout with a radio or phone can be very helpful. 1 Link to comment Share on other sites More sharing options...
