Dave Shackelford Posted 14 hours ago Share Posted 14 hours ago I have a 2005 Camelot 40 pdq with 156k miles. I suspect my turbo is not working. I get some black smoke (small amount) when I climb a hill. Then smoke goes away. I am not hearing that familiar turbo wine I am use to hearing when I accelerate. is there a way to Check the turbo while on the road ? Dave Link to comment Share on other sites More sharing options...
Marine Boy Posted 13 hours ago Share Posted 13 hours ago No boost pressure gauge on dash? Link to comment Share on other sites More sharing options...
Dr4Film Posted 13 hours ago Share Posted 13 hours ago I think the Camelots have the VGT Turbos. AS John stated have you seen a reduction in your normal boost pressures? Link to comment Share on other sites More sharing options...
Dave Shackelford Posted 13 hours ago Author Share Posted 13 hours ago 8 minutes ago, Marine Boy said: No boost pressure gauge on dash? I have 15% which is normal Just now, Dave Shackelford said: I have 15% which is normal Correction - 10 to 15% which is normal Link to comment Share on other sites More sharing options...
Dr4Film Posted 13 hours ago Share Posted 13 hours ago (edited) I doubt that 15 psi is normal unless you are referring to level road driving and not pulling a grade as you stated in your first post. My Cummins ISC-350 was normally around 23-25 PSI. My now Cummins ISL-400-2 is in the 30's psi. Edited 13 hours ago by Dr4Film Link to comment Share on other sites More sharing options...
Dave Shackelford Posted 13 hours ago Author Share Posted 13 hours ago 6 minutes ago, Dr4Film said: I doubt that 15 psi is normal unless you are referring to level road driving and not pulling a grade as you stated in your first post. My Cummins ISC-350 was normally around 23-25 PSI. My now Cummins ISL-400-2 is in the 30's psi. 7 minutes ago, Dr4Film said: I doubt that 15 psi is normal unless you are referring to level road driving and not pulling a grade as you stated in your first post. My Cummins ISC-350 was normally around 23-25 PSI. My now Cummins ISL-400-2 is in the 30's psi. I have driven this MH for 20 years and that has always been the readings 2 minutes ago, Dave Shackelford said: I have 15% which is normal Correction - 10 to 15% which is normal Just now, Dave Shackelford said: I have driven this MH for 20 years and that has always been the readings Correction - 10 to 15% which is normal. 30 on my boost gauge would be fully pegged. Just now, Dave Shackelford said: I have driven this MH for 20 years and that has always been the readings Correction - 10 to 15% which is normal Link to comment Share on other sites More sharing options...
Dr4Film Posted 13 hours ago Share Posted 13 hours ago @Tom Cherry owns a Camelot. Obviously he knows more about the VGT Turbo than I do. I am out of my expertise with your engine/turbo combination if 15 psi is normal. Hopefully, he will have your answer. Link to comment Share on other sites More sharing options...
Ivan K Posted 12 hours ago Share Posted 12 hours ago Not sure about the reference to percentage vs PSI. 15% of what? If you have black smoke, the engine is not getting enough air in reference to injected fuel. Could be air filter or leak in pressure side piping but there should still be noticeable decrease in the intake PSI reading, if there wasn't enough air to compress or VGT wasn't opening correctly. It is either not enough air or too much fuel from injector(s). 1 Link to comment Share on other sites More sharing options...
Solution Tom Cherry Posted 12 hours ago Solution Share Posted 12 hours ago 39 minutes ago, Dave Shackelford said: I have driven this MH for 20 years and that has always been the readings Correction - 10 to 15% which is normal OK...since Richard pulled me into this... FIRST. It is suggested that you review several sections of the Manual. Go to page 9-330. That is a PICTURE of your instrument cluster. There is also a description. The TURBO BOOST gauge is calibrated or reads in PSI. That is the amount of PRESSURE that the VGT (Turbine) is producing. At idle...THAT IS LOW. When you "GET ON IT", the Gauge should read HIGH. HINT...the HIGHER the READING...the LOWER your MPG. Some use it as FUEL economy gauge....if you are a GEAR HEAD, then you know that a car engine pulls Manifold Vacuum. The HIGHER the reading....the BETTER....as you don't have your FOOT in it. When you accelerate rapidly....the vacuum reading drops...and it means....FLUSHING THE CARBURETOR. Now, @Frank McElroy is the EXPERT HERE BUT, you can also find the answer by GOOGLING. We, the Moderating Staff, encourage that... here is the best link. I used "Normal Turbo Boost Cummins ISL Motorhome". That Google search got a lot of hits. Try it. This one makes the most sense...and I remember it sort of mirrors mine... https://www.irv2.com/forums/f115/isl-400-normal-boost-value-129174.html IF you have never seen upwards of 30 or above....and NOW see black smoke....time to go to a CUMMINS dealer or any DEALER that has the Cummins Insight Software and have the pull the DATA. ODDS ARE....YOU GOT A PROBLEM. NOW, we often get the question... My engine does THIS....and I have a Scanner and got XXXX Engine Code. How do I FIX. The correct answer, for most folks. YOU DO NOT. You need a qualified TECH or someone with the Insight Software (it connects to the ENGINE) and find out WHAT is GOING ON... What is NOT working right. YES, we have members that have a LOT of Diesel Tech expertise and they "know what to do" or what to check BUT, if your engine...on HARD acceleration has NEVER been that high... TIME FOR A QUALIFIED TECH to look at the print. NOW... If you memory is like mine.... When a Tech Downloads the data or the files....there is at least ONE place that will tell you the MAX Boost....if MY memory is correct. SO...that's my response.... Link to comment Share on other sites More sharing options...
96 EVO Posted 12 hours ago Share Posted 12 hours ago I see 34 psi boost pressure with my 400 ISL under heavy load. Link to comment Share on other sites More sharing options...
Old Dog Posted 11 hours ago Share Posted 11 hours ago My first recommendation would be to tighten all the boost hose clamps. Might also be good time to remind everyone to give their turbos and cool down period before shut down. 1 Link to comment Share on other sites More sharing options...
Dave Shackelford Posted 7 hours ago Author Share Posted 7 hours ago This is my setup operating at 55 mph on a level road Alidian screen shot.HEIC Turbo Actuator.HEIC Boot gauge.HEIC Also ran my scan gauge and no errors. Link to comment Share on other sites More sharing options...
96 EVO Posted 6 hours ago Share Posted 6 hours ago (edited) This an ISC or ISL engine you have? Just looking at your boost gauge that only reads to 30psi 🤔. Edited 6 hours ago by 96 EVO Link to comment Share on other sites More sharing options...
Dave Shackelford Posted 5 hours ago Author Share Posted 5 hours ago ISL400 Link to comment Share on other sites More sharing options...
96 EVO Posted 5 hours ago Share Posted 5 hours ago (edited) That's odd. Like I posted earlier in this thread, I see 34 or 35psi under hard load. My gauge goes to 50 psi. Edited 3 hours ago by 96 EVO Link to comment Share on other sites More sharing options...
