Happydad Posted 5 hours ago Share Posted 5 hours ago Greetings all, We are doing a bit of modernizing of our beloved 40’ beasty, and are getting ready to install new flooring, backsplashes, and possibly new wallpaper. My questions are the materials I would like to use in this project. I am thinking of using: LVP Flooring, peel and stick glass tiles, and some kind of wallpaper. Any constructive recommendations would be appreciated. Thank you! Link to comment Share on other sites More sharing options...
Chargerman Posted 5 hours ago Share Posted 5 hours ago I used the adhesive material when I installed our new backsplashes. I thought it would be a good choice to allow some flexibility and it has worked out really well well. I removed the old tile first which turned out to be real easy as it is glued to a piece of plywood which was then attached to the wall. Link to comment Share on other sites More sharing options...
JDCrow Posted 5 hours ago Share Posted 5 hours ago We’ve done LVP. Out of necessity. Was a good upgrade. Link to comment Share on other sites More sharing options...
Happydad Posted 4 hours ago Author Share Posted 4 hours ago 1 hour ago, Chargerman said: I used the adhesive material when I installed our new backsplashes. I thought it would be a good choice to allow some flexibility and it has worked out really well well. I removed the old tile first which turned out to be real easy as it is glued to a piece of plywood which was then attached to the wall. Are you referring to peel and stick tile backsplashes? 1 hour ago, JDCrow said: We’ve done LVP. Out of necessity. Was a good upgrade. Thanks for your response. Wow, quite the project. Do you think it was a necessity to remove the cabinets? I’m sure it’s a cleaner way to do it, but wow! Link to comment Share on other sites More sharing options...
Chargerman Posted 3 hours ago Share Posted 3 hours ago No. I used regular tile and bought a roll of the double sided adhesive product made for tile. Link to comment Share on other sites More sharing options...
